![]() | Home > Maintenance & Modifications > Metal Expoxy Putty - Any tips |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I mixed it in one go. It doesn't take long to do them all
ssg Member Since: 01 Mar 2018 Location: North East Posts: 65 ![]() ![]() |
Hi,
I used a small amount of chemical metal placed in the torx hole with a small screwdriver and put a 5mm ball bearing in each one, then wiped away any excess. ![]() |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
So what's the plan if the door needs removing?
Glad my doors aren't desirable |
In the highly unlikely event that a door needs removing you can dig it out with a scriber but it will take time!
The whole point is it sends a visible message to any would be theif who is after your doors or the complete vehicle that you have thought about security. |
Imax Member Since: 09 Apr 2018 Location: South West England Posts: 28 ![]() ![]() |
Yep that’s the plan... never had to remove doors of any car, so hopefully nothing changes.
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 ![]() ![]() |
Use a damp cloth for a smooth finish
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 ![]() ![]() |
Doors may not need removal but the mirror is held on with the door hinge
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
The LR hinges need replacing on a fairly regular basis too.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
![]() The hinges from the factory have a pretty poor finish I notice or is it just me? I assume it's due to manufacturing purposes but all the same I've never had a problem with mine. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 Last edited by custom90 on 4th Jul 2018 10:10pm. Edited 1 time in total |
The standard hinges are pretty rough castings.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
This guy goes to great lengths to smooth out the rough finish on Defender door hinges
For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
