Home > Maintenance & Modifications > Metal Expoxy Putty - Any tips
Imax
Hi,
Looking to apply metal epoxy to my door bolts... instructions seem fairly straight forward!
It appears a few of you have done this and I was wondering if there are any tips you can share before I start? I guess one might be only mixing a small amount each time.
Thanks in advance
Post #716061 4th Jul 2018 10:50am
williamthedog
I mixed it in one go. It doesn't take long to do them all Thumbs Up
Post #716066 4th Jul 2018 11:14am
ssg
Hi,
I used a small amount of chemical metal placed in the torx hole with a small screwdriver and put a 5mm ball bearing in each one, then wiped away any excess. Thumbs Up
Post #716067 4th Jul 2018 11:16am
AJC
So what's the plan if the door needs removing?
Glad my doors aren't desirable
Post #716074 4th Jul 2018 11:49am
ssg
In the highly unlikely event that a door needs removing you can dig it out with a scriber but it will take time!
The whole point is it sends a visible message to any would be theif who is after your doors or the complete vehicle that you have thought about security.
Post #716087 4th Jul 2018 12:49pm
Imax
Yep that’s the plan... never had to remove doors of any car, so hopefully nothing changes.
Post #716106 4th Jul 2018 3:08pm
stephan123
Use a damp cloth for a smooth finish Thumbs Up
Post #716151 4th Jul 2018 7:07pm
Trundlebus
Doors may not need removal but the mirror is held on with the door hinge
Post #716178 4th Jul 2018 8:39pm
The LR hinges need replacing on a fairly regular basis too.
Post #716192 4th Jul 2018 9:37pm
Off Topic
The hinges from the factory have a pretty poor finish I notice or is it just me?
I assume it's due to manufacturing purposes but all the same I've never had a problem with mine. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #716193 4th Jul 2018 9:49pm
The standard hinges are pretty rough castings.
Post #716194 4th Jul 2018 10:04pm
gilarion
This guy goes to great lengths to smooth out the rough finish on Defender door hinges
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #716257 5th Jul 2018 2:53pm
