Home > My Defender > Josh_WA's Defender 110 Double Cab |
Josh_WA Member Since: 24 Aug 2010 Location: Perth, W.A. Posts: 9 |
My VW "99" relay for the variable intermittent wipers arrived today so I installed that. it was pretty easy really, just unscrew the dash and then find the wiper relay by turning the wipers on and seeing which one clicks.... once i found it i yanked it out and replaced it with the "99" relay then screwed up the dash again.
It works a treat and is so much better to have either one wipe when you just quickly press the wash button for a quick clean or 3 wipes when you want a bit better clean by touching the wash button a bit longer. ( previously it was 5 wipes whenever you pushed the button no matter what). the variable intermittent is pretty cool also and better than standard. Pretty good mod for $15 Anyway here are some pics. Relay ready to be installed This is the relay that needs to be swapped out.... second from the right next to the flasher relay. 99 relay installed ready to put instrument cluster back on ________________________ Josh 2006 Defender 110 Double Cab |
10th Mar 2011 2:23am |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 |
Nice truck Josh 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy |
19th May 2011 7:01am |
Unfortunately i did not import this one it was imported about 12 months before i bought it... ________________________ Josh 2006 Defender 110 Double Cab |
19th Jun 2011 6:13pm |
nzdefender Member Since: 30 Jun 2011 Location: NZ Posts: 6 |
looks great w/ the top off! Trying to decide on which model Defender to pick up for myself.
30th Jun 2011 4:41am |
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 |
She's a beauty! Same truck as mine and colour etc. But yours looks better with the huge tyres and the red Aussie dirt on them!
Enjoy! |
8th Jul 2011 7:48pm |
4d47 Member Since: 19 May 2011 Location: Albany W.A Posts: 2 |
Cheers for that, It's an awsome looking truck surprising the doudle cabs are only just really getting popular.
15th Jul 2011 2:42am |
