Home > Technical > Boost Alloys
Merlin
Boost Alloys
Could anyone tell me if Boost Alloys are all standard or if there are any different varieties. I.e. different offsets.
The reason I ask is that my Puma pulls to the left, but only when fitted with a set of boost alloys that I bought off a 2005 Defender. These are fitted with general grabber 235/85R/16.
When I fit BF Goodrich 235/85R/16 KM2s on the original rims the car drives straight.
This is a bit of a puzzle, so any suggestions would be appreciated.
Merlin
Post #71541 18th May 2011 5:36pm
BigMike
are the boosts and grabbers balanced? as far as I am aware boosts are boosts, there are no offset variants.
Post #71557 18th May 2011 6:34pm
Merlin
Yes, I've swopped them front and back, also side to side but it's the same.
Merlin
Post #71559 18th May 2011 6:35pm
Tazz
Does it pull under braking or ordinary running?
Also, it might sound silly, but perhaps your original rims pulled slightly to the right, which was offset by uneven braking/steering?
Tazz
Post #71713 19th May 2011 8:58pm
mooro47
England 2003 Defender 90 Td5 XS CSW Java Black
Are they genuine LR one's? That may make a difference. Bit of a guess but if the only difference between it pulling to one side and not pulling is when you put the different rims on...? Are the AT tyres in good condition? Not distorted or anything?
Post #73070 27th May 2011 2:24pm
