![]() | Home > Technical > Boost Alloys |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Could anyone tell me if Boost Alloys are all standard or if there are any different varieties. I.e. different offsets.
The reason I ask is that my Puma pulls to the left, but only when fitted with a set of boost alloys that I bought off a 2005 Defender. These are fitted with general grabber 235/85R/16. When I fit BF Goodrich 235/85R/16 KM2s on the original rims the car drives straight. This is a bit of a puzzle, so any suggestions would be appreciated. Merlin |
are the boosts and grabbers balanced? as far as I am aware boosts are boosts, there are no offset variants.
Yes, I've swopped them front and back, also side to side but it's the same.
Merlin |
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
Does it pull under braking or ordinary running?
Also, it might sound silly, but perhaps your original rims pulled slightly to the right, which was offset by uneven braking/steering? Tazz |
