![]() | Home > Puma (Tdci) > stranded - Immobiliser? |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Simple things first and you have probably checked already that the earth lead is tight on the battery?
scottchad01 Member Since: 17 Jan 2018 Location: North Wales Posts: 94 ![]() ![]() ![]() |
yeah completely un-attached and re-attached the battery still no luck! i read somewhere about some 'code' that needs to be entered to disable to the immobiliser through some sequence with the key but not sure if that was a thing or someone taking the P*ss
Then remove and replace the relays under the drivers seat in turn. They should be a good tight fit
I might be wrong but don’t you have to leave the battery off for 30 mins to reset everything? I’m sure someone will be along soon to tell me I’m wrong
![]() My build thread http://www.defender2.net/forum/topic17615.html |
JMG Member Since: 16 Apr 2014 Location: Surrey Posts: 222 ![]() ![]() ![]() |
There’s definitely something to the code thing but
If you have your drivers pack with you you may have the method and unlock code in it.
The AA guy has just checked the relays under the seat, and yeah i have the drivers pack with me any ideas where that code would be? This guy reckons that the code is only on the newer vehicles and morn this one
still no luck getting it started as of yet but found a separate fuse under the drivers seat that keeps blowing every time a new one is inserted and ignition switched on, will post a pic tomorrow when i have time to see if any of you fellas recognise what its connected to, thanks for the help guys
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
S.H.M.B.O. had this problem a couple of years and some on here suggested that she get out , lock the vehicle wait 2 minutes the unlock and try and start it . That worked and still does , if I remember correctly its down to the immobiliser and key fob. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Fuse 8 10amp white / green wire ign input too AS10 alarm unit and battery back sounder AS10 alarm gray plug pin 10 ign input and battery back sounder pin 1 may not be your problem or fix will see the pic Last edited by dorsetsmith on 29th Jun 2018 11:59am. Edited 1 time in total |
this is the fuse that keeps blowing (under the drivers seat) not sure the photos will be clear but any help will be appreciated
![]() Click image to enlarge (circled in black) ![]() Click image to enlarge |
and thanks again for all the comments, im slowly working through checking each when i have a spare minute
marcoegyptos Member Since: 16 May 2009 Location: Vetraz-Monthoux Posts: 29 ![]() ![]() |
Holder fuse P110 , fuse 15A , feed the ECM
Check under the bonnet , chafing wire . |
