Home > Puma (Tdci) > Swap of 2.2 and 2.4 Engine from Transit to Defender
Asher111
Pakistan
Dear All,
Hope you all are having a fantastic day! If you can help me with this query of mine it will make my day also.
I have a 2.2 and 2.4 Puma Defender. Both are manual with rear wheel drive. Both of my engines are destroyed due to not changing the oil! I know its my fault and I hate that I do not get to drive it now. I have contacted land rover and they are selling the engine at 8000 GBP each which is a rip off!
I want to but a completely new engine and not used engines. I have researched and found that ford produces these engines for Landys. I got a quote from ford for 2000 GBP each for 2.4 and 2.2 with ford PN 1848692 & 1850921 respectively.
The real question comes now. I have heard that the sumps are different to Landys engines so I can replace that. However are there any other differnces? Any difference at all? I will be importing these engines from UK. Therefore I cannot afford the risk as I will be paying a lot in freight and customs duty here is 110% on car parts which means importing these will cost me 3000 GBP above the cost of the engine itself. Therefore I require honest answers from you guys so I do not import the wrong engines!
Regards,
Asher
Post #714709 27th Jun 2018 12:20pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
M&D engineering supplied my 2.4 land rover engine brand new at £2850.00 2.2 engines cost the same. Uk phone 01480277750 May be worth a bit extra to ensure a proper job!
They were easy to deal with and very helpful.
Post #714723 27th Jun 2018 1:04pm
Caterham
as you say the sump is I believe different but also ECM programme (albeit I don't think is too important as it should be a fairly easy fix to re-map it).
good luck - remember the oil next time!
Post #714724 27th Jun 2018 1:05pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
http://www.defender2.net/forum/post590949.html Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #714728 27th Jun 2018 1:13pm
Asher111
Pakistan
Thanks for the quick replies guys!
Just contacted MD Engineering and they are offering a price of 2500 GBP each. However I got a new quote from Hendy Power for ford engines. 2.4 at 1593 and 2.2 at 2166 GBP.
That is a very good price. So if anyone still has answers if Ford engine can be utilized it would be appreciated. As it would save me a few $$$.
Thank you in advance all!
Post #714730 27th Jun 2018 1:15pm
Asher111
Pakistan
Ian I was hoping that you would respond! I saw that thread before creating this one and you seemed to know what you were saying. Should it be a simple swap for 2.2 as well?
Post #714732 27th Jun 2018 1:18pm
ian series 1
The 2.2 is a different beast all together, lots more on the emission side of things, the High pressure fuel rail changed, as did the style of injectors, the EGR changed too.
I’ve recently had 2 vans in that were 8 months apart, both MK 7s but had different DPFs and sensor arrangement.
For fear of your situation, and location, I wouldn’t like to say for definite either way?
They still share the same block and top end, but subtle differences may catch you out depending on application?
2.4s changed very little through production as they weren’t around long before they were superseded by the 2.2. 80" 80" 86" 88" 90"
Post #714738 27th Jun 2018 1:34pm
Asher111
Pakistan
Uhmm! So you are saying my best bet would be MD engineering?
Post #714744 27th Jun 2018 1:50pm
Asher111
Pakistan
And they should really change the name of the engine if they are going to make changes to it. It is causing a lot of confusion.
But thank you all. I think I will go with MD Engineering.
Post #714745 27th Jun 2018 1:52pm
ian series 1
If it was myself, then yes Thumbs Up 80" 80" 86" 88" 90"
Post #714763 27th Jun 2018 2:35pm
zsd-puma
'Puma' Is the development code name and the name given to the 'family' of engines.
The 2.4 'Puma' is actually called the ZSD-424 and the 2.2 is the ZSD-422. There's also a ZSD-420, which was the 2ltr version used in the Mondeo. They're all related, but there was ongoing development throughout the engine's production. Which is why when you buy parts for cars you'll often find a certain part will be listed for engines up to a certain serial number then a different one for anything above that serial number.
The early Transit 2.4's were mechanical direct injection, the core engines may be the same as the TDCI versions, but I would stick with a TDCI lump just in case.
Also check what exactly is supplied. The Land Rover supplied one for example is more expensive, but it 'may' be a complete engine with injectors and manifolds fitted or at least include the cylinder head and cams etc. The Ford unit might only be a short engine (just the Block, crank, rods and pistons). If you've run them with filthy oil, then chances are the cams and followers will be shot too, plus the oil pump, timing chain and guides etc. Also the price from your local Land Rover dealer would include import duty.
That'll be irrelevant, as one would just use the Defender's existing ECM and wiring when doing an engine replacement.
Post #714765 27th Jun 2018 2:41pm
ian series 1
Quote,
Duratorq engines were a mile apart from the TDCI,
Forget they exist in this case. Wink 80" 80" 86" 88" 90"
Post #714774 27th Jun 2018 4:03pm
zsd-puma
I suspected that might be the case, but never having actually stripped either down to a bare block to compare the blocks I wasn't sure.
Post #714782 27th Jun 2018 5:02pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Re: Swap of 2.2 and 2.4 Engine from Transit to Defender
Hi Asher,
Asher111 wrote:
[...]. Both of my engines are destroyed due to not changing the oil! I know its my fault and I hate that I do not get to drive it now. [...]
As a side note, and even if it may sounds obvious, once you've sorted the engine, do not forget there's more than just the engine that needs oil change, front and rear diffs, gearbox and transfert box also need lubrication. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #714930 28th Jun 2018 8:29am
