![]() | Home > Technical > Indicator cancelling tab on 1993 90 |
I'm pretty sure it's 6/12 o'clock on all models. I replaced the switch on my '91 90 and the blue collar had an arrow moulded into it (just visible pointing the wrong way on this pic) that needed to point left for it to work. That leaves the slots for the steering wheel lugs top and bottom.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
Thanks LRA. I presume you rotated the collar 90° ? That's where I have mine but indicators are cancelling before I turn. I'll try rotating it through 180° and see if that works.
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
i have only ever seen the ring top to bottom; even on the early steering wheel the ring was like this. The later cast legs also top to bottom
![]() Click image to enlarge ![]() Click image to enlarge |
Yeah, that's right. Although I experienced the same problem where the damn things would cancel almost as soon as I turned in one direction. I did wonder if I'd messed up something inside by turning it away from it's centre position so I tried to reset it but with only limited success, to be honest. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
