Home > Puma (Tdci) > Immobilizer removal
Page 2 of 2 <12
zsd-puma
Blackwolf mentioned just disabling the coil. If you just disable the coil, you still have the immobiliser operated by the remote, so if the remote fails - the switches in them can fail without warning. You won't be able to disarm the immobiliser easily.
Fo example if you lock with the fob, then when you come to unlock it if the fob doesn't work the alarm will sound when you open the door and you'll need the EKA to shut it up. Just turning the key in the ignition will no longer work.
You'd have to be unlucky, but it's a potential drawback of just disabling the coil.
If you disable to security on the 10AS completely then of course you don't have any of these issues.
Post #714438 26th Jun 2018 6:25am
hornet
HardCharger wrote:
By disabling the immobilizer, you can forgo all this potential drama. As for the FOB running out of batteries, the truck will warn you about those long before they're dead. If you neglect the warning signs, then it's on you.
You mean that the function:
Battery Error: When set to ENABLED this configures the alarm to notify the user via the security LED that the plip has a low battery in accordance with the other settings which affect this function's operation. When set to NO the function is totally disabled.
still works, even when the immobilizer is deactivated? That would be great, doe to the deactivation I see no red ligts any more....
Post #714442 26th Jun 2018 6:47am
HardCharger
Hmm... If that's the case, maybe I am wrong?
My thought is that you are just deactivating the immobilizer and not removing the 10AS. This being the case, all other functionality except the immobilizer should still be working.
Well, I'm sure more experienced member than I can chime in. We are all learning after all. Besides, I could be wrong.
Post #714455 26th Jun 2018 7:36am
Yes, although you will probably also have to configure the alarm setting in the AS10 so that key unlock disables the alarm.
On a standard configuration if you lock the car with the key and unlock with the key I believe that the alarm will sound. If you lock with the key and unlock with the fob the alarm will not sound. This can be changed using most diagnostic tools.
Post #714475 26th Jun 2018 9:37am
hornet
That's exactly how it behaves. I disabled Arm on lock, Plip immobilize and Key mobilize and have a simple central locking controller now, no more LED in any situation.
The question is if the LED will work when a low battery in the fob is detected. But anyway, I change it yearly.
Post #714485 26th Jun 2018 11:26am
zsd-puma
the other difference between locking with the key vs. the plip is the interior protection (ultra sonics) will be disabled when you lock by key. This allows you to lock pets in the car without them setting the alarm off constantly.
Post #714568 26th Jun 2018 7:34pm
Page 2 of 2 <12
