Home > Technical > Ignition switch wiring help please
Bps
Wanting to go from the old type ignition switch to new type with steering lock
1 is brown
2 is white black
3 is red white
4 is brown
5 is brown and red
If I swop them straight over number for number it won’t start
I just wondered if anyone could advise a different way of wiring?
Bps
Post #714030 23rd Jun 2018 3:08pm
mark13
United Kingdom 2004 Defender 90 2.5 TD HT Cairns Blue
Sorry I can not directly answer your question but I can tell you a way I would find the answer. First draw a grid 5 high 5 wide three times. Then get the switches on the desk and get a multimeter and check the continuity between each pin on the first switch, marking a cross is each box on the grid that has a connection. Then draw another 3 grids and do the same on the new switch. The pin config will then be obvious when compare the grids.
Post #714040 23rd Jun 2018 4:26pm
Bps
Thumbs Up
Post #714044 23rd Jun 2018 4:42pm
Bps
It’s only 2 Switches, managed to double post the 2nd picture
Post #714045 23rd Jun 2018 4:47pm
Martin
Site Admin
What's the part number of the new switch please?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #714046 23rd Jun 2018 5:18pm
Bps
Hi Martin, Part number is QRF100870
Brad
Post #714050 23rd Jun 2018 5:38pm
Martin
Site Admin
New switch is PRC2735 aka Lucas 162SA
Connect as follows:
1: White = Ignition switched out
2: Brown/red = glow plug
3: White/Black = fuel solenoid
4: White/red = starter
5: Brown = battery live in  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #714056 23rd Jun 2018 6:09pm
Bps
Many thanks Martin 👍
That’s tomorrow mornings job sorted. Much appreciated !!
Post #714060 23rd Jun 2018 6:36pm
Martin
Site Admin
I know you said brown twice in your first post but I am assuming that's a typo and one should be white (old pin 4). If you actually have two browns then the one to your old terminal 4 is the ignition switched out and should go to new terminal 1.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #714065 23rd Jun 2018 6:48pm
Bps
Typo, should read white 👍
Post #714071 23rd Jun 2018 7:20pm
Martin
Site Admin
Did it work? (fingers crossed!)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #714690 27th Jun 2018 10:08am
Bps
Spot on Martin, many thanks I should have posted sooner, your help is very much appreciated. It’s surprising how the small things make a difference. I’d not realised how stiff the old barrel was and it’s nice having a bigger plastic key instead of the old small metal one 👍
Post #714761 27th Jun 2018 1:34pm
Martin
Site Admin
Great Very Happy  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #714770 27th Jun 2018 1:55pm
