Home > Technical > Electric Window Stopped Working
Merlin
Drivers door window won't go down. Went up then nothing.
I've read all the posts about the wires in the door jam breaking and I've checked the voltages against the values given in the relevant posts, but I can't find the fault.
What's next to check?
Peter
PS repaired the red and blue wires in the past.
Post #714002 23rd Jun 2018 1:08pm
zsd-puma
I just replaced the switch on mine, if I held it in it was smoking and didn't feel as positive as it should. Window has been fine since.
They're about £25 from Land Rover.
Post #714003 23rd Jun 2018 1:33pm
Merlin
Strange you should say that. My switch went 'intermittent' a few weeks ago and I changed it out. I'm tempted to buy a new motor but that is expensive for a 'poke and hope' fix. Peter
Post #714014 23rd Jun 2018 2:19pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
The other sides works?
If that is the case just start to switch parts. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #714015 23rd Jun 2018 2:31pm
Before you spend anything just bridge the switch once removed.
If it works it’s the switch, if it doesn’t then the issue is elsewhere.
You don’t really want to buy one if it’s unknown if it works or not. 👍🏻 WeWillWin🇬🇧🇺🇸
Post #714016 23rd Jun 2018 2:43pm
Merlin
I've swopped the left and right switches and the fault stays with the RH window. I've even looked at the fault codes but is seems that it isn't something that has codes. Peter
Post #714019 23rd Jun 2018 3:03pm
Tdi4
Bit more work but switch the motor as well.
Then you know for sure if it is the motor or some problem in the wiring/fuse/earth a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #714023 23rd Jun 2018 3:28pm
zsd-puma
You could even connect the motor direct to a battery with a couple of bits of wire and see if it runs.
There's no body control unit on a Defender so windows are just simple electrics.
Post #714025 23rd Jun 2018 3:37pm
Might be worth continuity testing the wiring between the door rubbers with all the power shut down.
The motors don't tend to fail but it certainly is posssible, many times it is a broken wire or connection at fault. WeWillWin🇬🇧🇺🇸
Post #714035 23rd Jun 2018 4:48pm
Merlin
Good idea, a job for tomorrow. Peter
Post #714042 23rd Jun 2018 5:30pm
Bug
Can the switch be removed without taking the central console out? My fuse is OK so I'm thinking what the easiest option is - work from the switch out or from the motor in.
Post #935641 30th Dec 2021 2:24pm
Bug
Disregard my previous question - the switch is easy to replace, and it was the switch that was duff. Replacement on order.
Post #935674 30th Dec 2021 6:27pm
