Home > Maintenance & Modifications > Fluids for 1986 defender with 300 Tdi conversion |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 523 |
Engine 15w 40
Axles ep90 front axle swivels ep90 or the LR Swivel grease which is better if they are weeping oil Transfer box ep90 Gearbox if it’s an LT77 I am sure that’s ATF fluid Grease nipples I use GP Agricultural Grease - Morris or similar (if it’s good enough for a high output 250hp tractor with a 1000 rpm PTO shaft on the back it will be fine for a tiny LR drive shaft A good tip is that most farm supplies usually sell all the above and are far far cheaper than Halfrauds |
22nd Jun 2018 3:33pm |
Butch Member Since: 22 Jun 2018 Location: Northants Posts: 3 |
Thanks so 75w90 in everything other than the gearbox, how do I tell what gearbox Ive got in mine??
22nd Jun 2018 6:17pm |
LT77 reverse is up by 1st, it’s extremely likely it’s an LT77 as they were original spec for a 4cyl of your age - unless it’s been changed with the transplant
22nd Jun 2018 8:02pm |
Yes reverse is top left by first
22nd Jun 2018 8:12pm |
