![]() | Home > Td5 > TD5 WIPERS PARK SWITCH REPLACEMENT |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Ac no different
Remove near side dash end and also dash top You can reach inside old switch pops up and then unplug and reverse the process to fit the new one 20 min job Fit a genuine one only other wise aftermarket ones can burn your motor out when they fail 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
For LHD:
1-Undo and remove the two screws on the side of the AC plenum. 2-Unscrew the centre screw holding the unit at the middle by the shifter (but leave it in place ) 3- let the unit hang a bit like one or two inches to get at the lower dash wiper moter cover 4- unscrew the three screws securing the wiper lower dash cover and remove it 5- you now have access to the wiper motor and are able to remove it from there. 6- you can reach up, unplug the wires and do what you need to. The park switch is visible and accessible. Reverse all precedures to put it back together👍 Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Carolos1973 Member Since: 06 Sep 2013 Location: Limassol Posts: 7 ![]() ![]() |
Any youtube links or pics pls?
Thanks |
These should help with screw locations, and component locations. The plug is what the park switch plugs into. I am unaware of any videos. Good luck, its quite easy actually.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Many thanks i think that will work!!!!!
