Home > Puma (Tdci) > Defender recall letter |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I was wondering how you knew that they don't have the same ethos or that ? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
17th May 2011 11:12am |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 305 |
Well my 59 110 has been in for the recall last week. It returns this week for another diff oil seal, replacement of rusting wing mirrors, rusting rear sliding window catches. It then goes to another garage for attention to rusting bulkhead below front window rubber seal.
At least I had the chassis waxoyled. |
17th May 2011 11:38am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Where exactly is the rusting "Peanutbob" is it from under the lower window rubber, from under the window frame that has the foam sealant strip where it rests on the bulkhead or the bonnet hinge on the bulkhead?
Cheers Chris |
17th May 2011 12:00pm |
It's under the lower window rubber where the rubber joins the metal window frame, about 3 cms long.
17th May 2011 12:07pm |
Sounds like my old TD5, it had very bad rust all the way around the frame hidden by the window rubber. I only discovered it when I had the perished rubber replaced when it was 5 years old. The guy that did the work said it wasn't uncommon on Defenders as they don't put sealant in so water just sits behind the rubber most of the time
It was also the reason water made my roof lining drop as it filled up with water leaking from the sunroof rubber seal. He suggested I seal all my windows which i did and have done on the new one! Some say it's anal but of course it's common sense to look after something which costs so much when you are going to keep it a long time! I hope they get it sorted for you properly e.g. glass out, treat properly and inspect the rest of frame. It would be ideal if they could swing a new frame for you |
17th May 2011 12:29pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Blimey! One of the unlucky Defender owners by the sound of it Either that or you live in/by the sea. Defender 110XS SW gone... now VW California 180 4 Motion. |
17th May 2011 1:32pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Nothing happens here yet Eduardo
MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
17th May 2011 2:47pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Need to check the bulkhead but the rest I have had on my 09 110 |
17th May 2011 3:18pm |
I had an 03 90 also with rusting wing mirrors (on the arms). One might have thought that L/R would have requested their wing mirror supplier to improve the quality of their product by now/or change supplier. I don't quite understand when you are paying 25/30 thousand pounds uk sterling L/R feel putting ancient mirrors with 1970s Leyland quality is acceptable!
17th May 2011 7:01pm |
And why are the rubber seals around all the doors not glued in?? I have had the rear door seals replaced twice after they came away and the door catch mashed the strip. Both L/R and the dealer could not utilise glue, so I have now done so. All the other door strips come away with ease..
I've never come across such a wonderful and dreadful vehicle..I'll either sell it soon or keep it forever... |
17th May 2011 7:29pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
The satin black paintwork is thinner than a fag paper and it is still an issue.. i got my headlight rings replaced in Dec/10 and all the paint has fell off, side steps, chassis and mirror arms.. £32K Defender gets not 1p more rust protection than a Base model. We put up with it and to be honest the finish pre India was mince. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
17th May 2011 7:34pm |
Shouldn't think you'd get mince post India. They're a bit touchy about the sacred cow and that sort of gough.
17th May 2011 7:44pm |
Aye buddy.. MATRON, MATRON!!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
17th May 2011 7:46pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Still not got mine! I'm feeling left out.
17th May 2011 9:22pm |
