Home > Puma (Tdci) > Replacing a decat
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Replacing a decat
2.4 Puma - has a decat , I think the cat has been cut out and a pipe fitted in its place, leaving the bellows.
The bellows have been identified as the source of a very annoying vibration.
I’ve read how hard it is to remove the cat, with the sub frame and engine both needing to be moved.
However, would it be a much easier job to remove an already de-catted pipe to replace it like for like ?
Anyone else had failed bellows on their Exhaust down pipe? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #712584 16th Jun 2018 7:16am
jst
Just take the good crewmember out, slacker engine mounting bolt and back engine to one side. It's not a difficult job just time consuming. You need to remove crewmember to physically get the can out. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712609 16th Jun 2018 11:44am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Crewmember- Tom the Cabin boy or Seaman Stains?
Just love auto correction Rolling with laughter Rolling with laughter
Post #712612 16th Jun 2018 12:01pm
jst
Oops gbox crossmember Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712622 16th Jun 2018 1:01pm
meeerrrk
But if there is no can, because it’s a decat, does it drop straight out, or do you still need to make the space? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #712623 16th Jun 2018 1:10pm
You'll probably still need to remove the 'crewmember' unless the decat pipe is a 2-piece one, but shouldn't need to malarky about with the engine.
Curiously I don't remember having any trouble getting my cat out when the flange broke off, nor do I remember undoing any engine mounts.
Post #712700 16th Jun 2018 9:24pm
zsd-puma
I think the 2.2 with a DPF is much more difficult to remove and needs engines lifting and all sorts, but the 2.4 with just a cat is much easier.
Post #712714 16th Jun 2018 10:59pm
meeerrrk
Interesting- thanks.
Has anyone used the allysports decat pipe with the “cosmetic cat can” for new MOt requirements? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #712725 17th Jun 2018 7:15am
jst
you will still need to take the gbox xmember out as it wont drop far enough to get the bend out unless there is a flexible section in the aftermarket bit.
engine wont need touching.
i did do one without touching the engine mounts side of things but its easier to them. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712982 18th Jun 2018 12:21pm
Hal
In the 2.4 Puma it can be done. It's easier if there's two of you, one above in the engine compartment and one below. It's like doing those nail puzzles you get in crackers at Christmas - there's only one way to do it but working it out can be a b****r, especially if you're the one underneath putting it back.
Post #712987 18th Jun 2018 12:51pm
meeerrrk
thank you all for the valued input, much clearer now Thumbs Up My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #712994 18th Jun 2018 1:11pm
