Home > Technical > Engine revving but no power |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
sounds like its trying to run on ts own oil, if its reving by itself? disconnect the air in take pipe to the mainifold from the intercooler, it'll probably be oily anyway, but if this stops the whiite smoke,and reving, then this is your problem.
The thing then is to find where its coming from, either the bores / ring damage, and its via the little black filter on top o/s of head, or its the turbo oil seals or turbo itself. Good luck and keep us posted |
12th Jun 2018 6:45pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8023 |
i concur on the running on its own oil
but that would not explain loss of power to, my experience of vehicle running on from their own oil is there is plenty of power! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Jun 2018 6:02am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
^^^^ ditto, 200 Tdi Disco went like a train!!!
13th Jun 2018 11:00am |
ell130 Member Since: 03 Apr 2018 Location: Newport Posts: 5 |
Thanks for the help guys! I had it a bit wrong through, apparently when we were testing it, it was when the throttle was applied to the max that it started revving itself....any ideas?
13th Jun 2018 12:22pm |
same applies, the higher the revs, the more oil is being forced in to burn, from where ever. have you checked all your turbo hoses, especially the first one out of the turbo, as they break up internally, and can't see damage till you take it off. Do as I said, and remove the intake pipe from IC to manifold then try it, give it a few mins to warm up before you thrash the nuts off it.
13th Jun 2018 5:06pm |
does it do it with the throttle cable disconnected at the pump? Cheers
14th Jun 2018 8:46am |
so when it starts and runs fine it moves i take it? only stops moving when hot (define hot?) and then still revs but doesnt move.
manual? in ratio? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Jun 2018 9:46am |
