Home > Technical > Engine revving but no power
ell130
After some help please.
We've just completed the rebuild on my 300TDi 130 and everything was going fine until a few weeks ago the engine lost all power. It would rev but not move and we had to be towed home.
We assumed air was getting in the fuel as the exhaust fumes were white, so set about replacing the fuel lines, fuel sedimenter,fuel filter and housing, the lift pump, injector pump and injectors. The amount of fumes has greatly decreased but this has not fixed the revving problem.
The engine starts and runs fine, but once up to temperature and any throttle applied and released, the engine just starts to rev itself. We are at a loss of what to do next so any suggestions are welcome.
Thanks, Ell130
Post #712037 12th Jun 2018 12:39pm
yostumpy
sounds like its trying to run on ts own oil, if its reving by itself? disconnect the air in take pipe to the mainifold from the intercooler, it'll probably be oily anyway, but if this stops the whiite smoke,and reving, then this is your problem.
The thing then is to find where its coming from, either the bores / ring damage, and its via the little black filter on top o/s of head, or its the turbo oil seals or turbo itself. Good luck and keep us posted
Post #712094 12th Jun 2018 6:45pm
jst
i concur on the running on its own oil
but that would not explain loss of power to, my experience of vehicle running on from their own oil is there is plenty of power! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712150 13th Jun 2018 6:02am
VVS210
^^^^ ditto, 200 Tdi Disco went like a train!!!
Post #712173 13th Jun 2018 11:00am
ell130
Thanks for the help guys! I had it a bit wrong through, apparently when we were testing it, it was when the throttle was applied to the max that it started revving itself....any ideas?
Post #712183 13th Jun 2018 12:22pm
yostumpy
same applies, the higher the revs, the more oil is being forced in to burn, from where ever. have you checked all your turbo hoses, especially the first one out of the turbo, as they break up internally, and can't see damage till you take it off. Do as I said, and remove the intake pipe from IC to manifold then try it, give it a few mins to warm up before you thrash the nuts off it. Sad
Post #712225 13th Jun 2018 5:06pm
jst
does it do it with the throttle cable disconnected at the pump? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712300 14th Jun 2018 8:46am
jst
so when it starts and runs fine it moves i take it? only stops moving when hot (define hot?) and then still revs but doesnt move.
manual?
in ratio? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712308 14th Jun 2018 9:46am
