Home > Maintenance & Modifications > Terrafirma HD springs
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
The time has come for me to replace the tired rear springs and shocks on my 110 XS SW. I don’t want any lift, I normally run the vehicle with a roof tent, and maybe a few other items up there total weight about 100kg. I’ve got no seats in the back and load this area with the rest of my camping and a recovery gear, hard to guestimate the weight, but no more than 100kg.
My local Indy is recommending Terrafirma Pro Sport shocks with Terrafirma HD standard height springs. My only concern is whether the ride will be too harsh using HD springs. Has anybody else got this setup or used these springs?
Thanks 2010 Defender 110 Station Wagon, Santorini Black.
Post #711419 8th Jun 2018 12:02pm
For your usage, why not stick with original spec. springs? New standard parts will transform it. Darren
Post #711454 8th Jun 2018 5:33pm
ChrisCM
Yes, am considering that as well, just thought I’d see if anyone has experienced this particular set up, when you think about it my loading is no more than all 7 seats occupied by adults with a small amount of luggage so the standard springs should be ok. 2010 Defender 110 Station Wagon, Santorini Black.
Post #711466 8th Jun 2018 6:16pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi Chris
I put HD springs on the back of my110 DCPU and it gave a harsh ride. I tow a big trailer fairly regularly and that was the only time I appreciated them, the rest of the time I’d wince over every pot hole !
I’ve swapped them back to a standard spring but with Bilstein B6 shock absorbers and what a difference to the standard shock, I’d highly recommend
Happy searching
Rich
Post #711545 9th Jun 2018 7:04am
ChrisCM
Thanks Rich,
You’ve confirmed what I thought, seems to be the view of most, I think I’ll stick to standard springs with the new shocks, can you or anyone recommend a good brand of, preferably OEM, standard springs?
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #711557 9th Jun 2018 8:27am
You'll probably find that genuine LR ones aren't expensive. Darren
Post #711561 9th Jun 2018 8:45am
Bluericky
Second that , standard springs seem fine
Post #711565 9th Jun 2018 8:53am
Mountain_man
Wales
Originally bought TF springs for my 110 when I rebuilt it but the rears were far too hard. Kept the fronts and replaced rears with new take-off in brown/purple variety, Nice progressive HD spring. I think the green/yellow/green ones offer a bit more comfort though if you are not always towing or carrying heavy loads, but are harder to come by as take-offs. Think mine were £40 the pair.
Post #711573 9th Jun 2018 10:19am
ChrisCM
All sounds good to me, won’t be doing it till start of next month (cash flow 😢) so got a few weeks to get the best deal! 2010 Defender 110 Station Wagon, Santorini Black.
Post #711576 9th Jun 2018 10:38am
jst
stick with std ones if you can, if you load it up heavy fit the air helpers.
OME shocks will transform it though. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #711637 9th Jun 2018 8:03pm
