Home > Maintenance & Modifications > Britpart Aluminium Ladder - DA3073
Page 4 of 4 <1234
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Thnx for the fast reply Thumbs Up
So this isn’t my solution unfortunately Big Cry
If have a safety device roll cage with different mounting Points for the ladder a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695671 23rd Mar 2018 12:33pm
Re: Britpart Aluminium Ladder - DA3073
LandRoverAnorak wrote:
Does anybody have one of these aluminium rear ladders fitted? On the face of it, they look pretty good but I can't find any detail about how the top is fixed to the body. It doesn't appear to be bolted but then also doesn't look like it hooks over the gutter Confused
Fitting instructions for this:
"This sits inside the gutter on the back of your Defender 90 or 110, and secures to the two bolts on the rear cross member. You may need to drill through into the roof to secure the top of the ladder. "
and Britpart, to their credit, state:
"Note - Please check as DA3073 partially covers the number plate and may not comply with your country's MOT regulations."
Post #695686 23rd Mar 2018 1:58pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Here’s my ladder, it sits in the gutter and also has 2 bolts through the rear roof panel and 2 bolts on the bottom. It does not obscure the number plate at about +- 30 degrees to each side. Don’t know the make but it may be a genuine LR one as the roof rack is.
 2010 Defender 110 Station Wagon, Santorini Black.
Post #695691 23rd Mar 2018 2:06pm
Ironically, that's exactly the same ladder as I have on my 90:
I'd discounted it, partly because it bolts on and partly because the supports that press against the body are very close to the lights. I plan to fit NAS lights and that will interfere. Darren
Post #695844 24th Mar 2018 9:26am
L110CDL
I spotted this and my passenger took a pic for me as another method for the number plate to be seen more easily with a ladder to the rack. The red arrow is to show you were the number plate light is located, hope this helps Wink
Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #706103 8th May 2018 8:27pm
dorsetsmith
discomog wrote:
With more and more ANPR cameras around I'm sure that MOT testers take even more notice of partially obstructed registration plates. An obscured plate will trigger an alert if the ANPR camera cannot read the number.
Cost for An obscured plate this can be £600 plant hire business i work of that using magnetic registration plates driver being stopped and fine (ANPR camera cannot read the number.)
Post #711398 8th Jun 2018 9:04am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Have now replaced my landrover ladder with a frontrunner one and jolly nice it is too! (had to have it bolted at the top as the pop top requires the roof gutter to be part of the raising roof )
Thumbs Up
 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #711404 8th Jun 2018 10:05am
ssg
I have a Britpart ladder fitted that covers the number plate as in the original post and I did drill the top mount and bolted it to the rear of the roof, must remember to remove it at MOT time........
Post #714298 25th Jun 2018 6:36am
JeremyJ
Britpart ladder, for the money it’s actually surprisingly good!
Plus Schnauzer blending into tent Very Happy
Post #714388 25th Jun 2018 7:50pm
Page 4 of 4 <1234
