![]() | Home > Td5 > TD5 chugs when cold |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Does ambient temperature make any difference to the chugging on start up? As in when its hot outside does the chugging go away? Sounds like, perhaps, it might be worth investigating if your glow plugs may be dodgey?
Good luck👍 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 639 ![]() ![]() ![]() |
Take it to diagnostics (Nanocom) and look for fault like injector open circuit - your description looks like a bad contact somewhere between engine ecu and injectors.
TD5 runs nice without working glow plugs, with only some of them working, the engine run can be v bit harsh, but only for very shot time, 10 mins is long time. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 ![]() ![]() |
Thanks for the replies. It is probably less than 10mins that it is chugging. It probably warms up after maybe 3-4.
The ambient temperature doesnt affect the chugging. It does it in hot or cold weather. Thanks. Instagram - @Land_Rover_Defender |
Madtom’s suggestion of getting it scanned for codes is a good one👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
I had similar problem - engine was running fine when cold, but after 15 mins one injector hesitate to work. Problem was clearly visible with Nanocom - there were fault codes. Repair was simple - remove the injector loom, press a bit the connector pins, replace with new Orings. After 6 year still running fine, and no more oil in loom thanks to new Orings.
Later I have repaired the same problem on another cars. No need for nee loom, some aftermarket loom were bad when they were new. So first diagnostics, them mechanical work. Another problem I have seen was sticking valve, because of bad hydraulic lifter. But it was noisy. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Will scan for codes as I am not sure what is causing the issue at all. Apart from this, the car is running great! Instagram - @Land_Rover_Defender
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2945 ![]() ![]() |
Exactly the same fault here, seemingly running on four cylinders.
New injector harness cured it. |
Yes that is exactly is Lightning, seems to be running on four cylinders. I will try a new injector harness then! Instagram - @Land_Rover_Defender
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
The injector harness is a service item. Worth changing regardless every couple of years
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
Mines always a bit meh.. until it's been on turbo boost. It's almost like the turbo bearings are a bit dry or tight until it's spooled up.
I know that's a bad description. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
