Home > Technical > LT230 Intermediate Shaft Seal Leak Fix
Verdict:
Should be fine.
50%
 50%  [2]
No way!
50%
 50%  [2]
Total Votes: 4
Freddie
South Africa 2004 Defender 110 Td5 USW Bonatti Grey
Hi guys,
Quick question.
I have a leaking intermediate shaft seal on my LT230 transfer case.
The leak isn't too bad, but it's bad enough to be annoying. I was planning on giving the gear and transfer boxes an overhaul when my clutch next goes. The trucks 15 years old with +200,000km of 'Africa miles' on the clock, so it would be worth doing.
A couple of years back, I was travelling through Namibia when my power steering box started dribbling fluid. A bush mechanic suggested adding a bit of brake fluid to the power steering reservoir.
It did the trick, and the leak is still 'fixed'...
I was wondering whether topping off the transfer case with a bit of brake fluid would do it any harm? Hoping to get a few more KM out of it before having to pull the damn thing apart..
The oil in there at the moment is Castrol 75w-90 GL4.
I also have a Roverdrive fitted which specifies "Use of API GL5 oils may cause corrosion of thrust washers and synchromesh parts, shorten the life of the overdrive and void the warranty".
Post #711266 7th Jun 2018 4:31pm
roel
I am not sure if that works or not , so I cannot comment on that.
My steering box is sweating a little too so how much brake fluid did you add?
I assume that your transfer box is leaking btween the gearbox and the transfer box where the end of the intermediate shaft is. Prbably just changing the O-ring will only be a temporary fix as the hole were the shaft sits is is worn out. So you probably need a new housing.
I had the same problem, changed the O-ring and the leak was back in some months so I tried something different. First I cleaned it very good without seperating the gearbox and tranferbox just worked from below the 90.
I made this:
I glued this with plenty off blue silicon in the area over the end off the intermediate shaft. I did this in November 2017 and still no leaks. Roel
2003 90 Td5 (2009-now)
Post #711361 7th Jun 2018 9:19pm
Freddie
Ha! I always get a kick out of seeing the lengths we land rover guys go to fix a leak.
By the sounds (and looks of it) we are talking about the same thing. If the hole is worn out - perhaps that's a good enough excuse to get my hands on a DURAspec LT230 from Syncro gearboxes... Wink
In the meantime, I'll whip up something similar and let you know if it works - thanks Roel!
Re brake fluid for power steering leak, if I remember correctly it was two caps full. The caps were small, so probably the same as two tablespoons.
Post #711390 8th Jun 2018 7:22am
roel
Thanks,
I will try that too. Very Happy Roel
Post #711647 9th Jun 2018 9:46pm
Freddie
It aint pretty but its installed - with LOTS of silicone. Will keep you posted..
Post #711918 11th Jun 2018 4:19pm
roel
That is not lots of silicon. Laughing Or was that a trial fit picture? Roel
Post #711981 11th Jun 2018 10:33pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I made it the "Ashcroft way" - dismantle the gearbox, make the oval hole bigger and press in a steel sleeve. Now after two years it is OK. It was a small job with lathe and mill. Most of time I spent thinking, how to do it and how to align everything. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #711984 12th Jun 2018 6:12am
Freddie
Trial fit.. You can't see the plate anymore Laughing
Post #712005 12th Jun 2018 8:19am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Hi Freddie
Is the fix still working?
Mine has just started leaking again after fitting new seal around 3 months ago Censored Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #718002 16th Jul 2018 11:10am
Freddie
Hi, Sorry for the delay in getting back to you.
Frustratingly I had run out of the normal Silicone that I use (Victor Reinz - great stuff!) and ended up using Loctite Grey, which ended up peeling off when I steam cleaned the undercarriage Rolling Eyes
Before that, it did seem to stop the leak and I'd bet when I redo it with the Victor Reinz it'd be a more than temporary 'temp fix'..
Give it a whirl!
Post #719614 25th Jul 2018 8:50am
Bushpig
No worries on the delay, I'm only back with my vehicle at the end of the week.
When you have the piece off, would it be possible to take some better measurements or perhaps a picture on a piece of graph paper? I'll only have a day before heading off up the west coast, hoping to make Eksteenfontein and would rather do the fix before going. I know it is being a bit lazy, but I must also do a full service (100 000km), all fluids, brakes, seal the wing ducting to the blower, etc & shopping. So any time saving would be a great help.
Did a quick Google and there are suppliers in Strand who stock the Reinz stuff, but only the Renzosil. Is this what you use or is it the Renzoplast?
Apologies for all the questions and requests...
Much appreciated Thumbs Up Jason Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #719642 25th Jul 2018 11:56am
Freddie
Hey Jason, No problem, I'll see what I can do!
I use the Reinzosil. In SA and Tonnesen / Midas Auto Spares store will stock the stuff.
Post #720648 31st Jul 2018 10:35am
Freddie
Hi Jason,
You inspired me to fix the thing..
I revised the design slightly to allow for the curve of the gearbox. It's also a little better fit so hopefully, it will create a better seal.
Here is a picture of the new design (right):
And a copy of it on graph paper.
I didn't have any, so I printed this one. Typically the blocks ended up being 12 x 12mm.
https://store.schoolspecialty.com/OA_HTML/...tion=Large
Hope that you can recreate it!
Will check back as to how well it works.
Post #720690 31st Jul 2018 1:45pm
Freddie
This is certainly the way to do it. Something for when I can be bothered to pull everything apart Whistle
Post #720691 31st Jul 2018 1:47pm
MadTom
It took 4 years to really start the work. Transfer box was fully covered in mud, sand and oil mixture at that time. The last point to start the work was clutch spigot bush - it started making bad noise and slowly during 4 year going to be worse, up to the state, that it was hard to shift between gears, and in low gear the car was moving with depressed clutch pedal. So spigot bush replacement - 3 GBP thing, and I made clutch and both gearboxes, because they has to be removed, to replace the bush. Small things can be a bit expensive to repair. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #720802 1st Aug 2018 6:47am
