Home > Puma (Tdci) > delay wipers
DOUG MALGARIN
United Kingdom 2009 Defender 110 Puma 2.4 USW Zermatt Silver
delay wipers
My delay wipers has stopped working . Is their a fuse . Question
Post #711133 6th Jun 2018 7:21pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Is it only the delay that is not working? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #711260 7th Jun 2018 4:58pm
dorsetsmith
Its one fuse for the front wipers
Post #711267 7th Jun 2018 5:34pm
dorsetsmith
Post #711272 7th Jun 2018 5:42pm
DOUG MALGARIN
YES got a order a new relay.
Post #711316 7th Jun 2018 9:00pm
CDN38
Relay was what I was thinking. Not sure if the Puma has adjustable delay intervals, or if it's like every other Defender and has only 1 delay speed that never seems to be the right one. If that's so, you could get a VW type 99 relay, which would allow you to set your own relay interval time.
https://www.ebay.co.uk/p/VW-Genuine-OE-357955531/652222743
Plug and play! it's a Landrover thing...
Post #711319 7th Jun 2018 9:08pm
Puma Defenders are like every other Defender with only a single speed intermittent setting. However, the VW '99' variable speed relay is indeed a plug and play upgrade:
 Darren
Post #711327 7th Jun 2018 9:26pm
williamthedog
^^^as said above best cheap modification you can do Thumbs Up
Post #711360 7th Jun 2018 10:19pm
DOUG MALGARIN
Thumbs Up Its working .New programmable delay relay . Thank for help.
Post #711456 8th Jun 2018 6:42pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Just a word of warning, the Ebay link above is a 19 relay not 99, I used the link and ordered the relay but it did not work, the guy sent me another and that did not work although the seller says its the same as a 99. I ordered a 99 from somebody else and the relay worked 100%. So I could have just been unlucky with 2 faulty relays, but looking on the internet for details on the 19 relay suggested that it not programmable.
The 19 relay seems to have a fixed 8 second delay that can not be changed like the 99. It works as a wiper delay but does not change from 8 seconds. Going to look at using it on the rear wiper to give a fixed delay maybe. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #714934 28th Jun 2018 8:49am
Ponclair
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Aintree Green
I also bought one of these from the same ebay seller. Have sent back for refund. Bought one of these instead: https://www.ebay.co.uk/itm/AUDI-VW-SEAT-SK...:rk:1:pf:0
Took about a week to arrive but works as expected.
Post #743366 1st Dec 2018 11:31am
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
How do you adjust delay if you fit VW relay
Post #743370 1st Dec 2018 11:36am
Ponclair
Switch on delay wipe and switch off again. Wait the desired delay you want then switch on again. Voila!
Post #743374 1st Dec 2018 11:49am
Flick on 'intermittent' and then off again before it completes it's sweep.
Wait until the screen reaches your 'wet' threshold and then turn on 'intermittent' again.
The relay will remember the time between the two operations and repeat until stopped or changed. Darren
Post #743375 1st Dec 2018 11:49am
Hendrix
Going to have to give this a go Smile
Post #743749 3rd Dec 2018 4:51pm
