Home > Puma (Tdci) > how to enter radio code.
zephyr4
I have the code but dont know how to enter it.
Picture of radio fitted.
Puma Tdci 2007 xs
Thanks for any help z4.
Post #710724 4th Jun 2018 1:16pm
zsd-puma
If I recall correctly, if for example the code is 4356;
press the 1 button 4 times, press the 2 button 3 times, press the 3 button 5 times, press the 4 button 6 times.
Then I think hold the up arrow on the tuning button for a few second and it'll beep storing the code.
Post #710730 4th Jun 2018 2:08pm
AMBxx
I think SAFE means that you (or someone else) has already exceeded the number of attempts:
http://www.defender2.net/forum/post310664.html
Post #710731 4th Jun 2018 2:09pm
zsd-puma
I think if you enter the wrong code it works like this;
Enter it incorrectly 3 times the radio shows 'safe' for 10 minutes, after 10 min you can try the code again, if you get it wrong again it'll show 'safe' for 20 min, after 20 min it will let you try again, but every time you get it wrong the waiting time doubles. I think you have to leave the radio on for the waiting time until the 'safe' disappears.
This is only from memory though, and I may be confusing things with the old Rover/Phillips radios.
Post #710732 4th Jun 2018 2:14pm
zephyr4
Followed this info.
Put in the 4 number code using each of the first 4 preset numbers on the radio. Each press of a preset button moves the code number up one. Once the 4 number code is entered press the preset 5 button to complete entering code.
Switch on and turn the volume up full to drown out the noise of the drive train.
Willie
Thanks for the replies.
Post #710747 4th Jun 2018 3:08pm
zsd-puma
I was half right then. Just pushing the 5 instead of up I got wrong. Laughing
Post #710831 5th Jun 2018 12:07am
