Home > Off Topic > Ctek Charger/conditioner - Not impressed
discomog
I've used a couple of Ctek mxs 5.0 chargers over recent years for vehicles that are not used as regularly as maybe they should. On attempting to start one of them yesterday all I got was a click from the starter solenoid. On checking the battery it was reading 12.6 volts with no load on it, as soon as I switched on the headlamps it was reading 5.5 volts indicating a duff battery.
My question is - the Ctek charger showed the battery was OK with all 8 lights on, indicating the battery was fully charged and on "maintenance charge" why did the Ctek charger/conditioner not detect a faulty battery? Can anyone explain the reason why?
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #710690 4th Jun 2018 8:02am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Because a Ctek charger is not a battery tester.
Post #710692 4th Jun 2018 8:05am
Balvaig
The charger is working as intended. It only reports an error if the voltage after steps 1-4 drops to 12v. You clearly had more volts than this so no error reported.
It might be worth trying to recharge the battery in Recond mode before buying a new battery.
Post #710706 4th Jun 2018 10:34am
Laurie
Leave the charger connected and momentarily switch the headlights on or the starter.
Check the charger report afterwards.
Post #710707 4th Jun 2018 11:16am
bear100
Put the charger in recon mode over night, it will bring your battery up to better than new! Then use the maintenance function Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #710719 4th Jun 2018 12:34pm
