Home > Td5 > Starting Problems TD5.
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Hi Folks,
I've gone through changing a few of the obvious. I've changed the Injector Loom, the Injector Seals and rings, and also the fuel filter valve.
When I put the key in the ignition and turn it i can hear the fuel pump. The starter keeps turning the motor over but it sometimes will and sometimes wont start. It was taking longer and longer to start even if the engine was warm. Now it barely starts after trying until i killed the battery.
I've charged up the battery and after a few times it started.. so I drove it around and i turned off the engine on a hill. I tried turning it over and again it wouldn't start. However, everytime I bump start it, it starts immediately. I've spent so much money trying to problem solve it. I'm convinced its the Starter motor, can it be anything else?
Post #710646 3rd Jun 2018 8:56pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Have you changed crank position sensor? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #710650 3rd Jun 2018 9:03pm
kweese
I was thinking it could be that too. Any thoughts?
Post #710652 3rd Jun 2018 9:09pm
pj2106
Very good possibility bud I had that before not cheap but if it starts on pull spot on I’d say a fair bet 2008 110 2.4 XS Utility (Hagrid)
Post #710656 3rd Jun 2018 9:27pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I would check the loom again, I replaced mine and within a month oil was creeping into the electrical contacts on injectors 3/4/5 cleaning these out it would start fine and run for a week or so. I have now gone to town on sealing another new loom and so far it’s all good. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #710667 3rd Jun 2018 10:04pm
NickMc
Put a load on the starter motor and see instead of throwing parts at it and changing the variables.
Post #710669 3rd Jun 2018 10:21pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
If you have a access to a nanocom or similar check the rpm when cranking if it's erratic it will be your starter motor that is shorting and corrupting the crank sensor signal, hence the reason it starts with a bump start.
Post #710671 3rd Jun 2018 10:24pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check your crank sensor. It is located on the passenger side of the flywheel housing. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #710880 5th Jun 2018 10:58am
NickMc
How is he going to check it? Why would he need to change it? what are the symptoms that tell you that?
Post #710933 5th Jun 2018 5:03pm
roel
Take your startermotor out and clean the contacts and the small gearbox it has. I did mine last year also because starting became slow. The grease in the gearbox was almost solid and I hardly could turn the motor by hand. Clened it and put grease in there and it starts now quicker then when I bought it in 2009. Roel
2003 90 Td5 (2009-now)
Post #711046 6th Jun 2018 8:17am
kweese
My starter turns the motor. I changed the crank position sensor yesterday and no luck. It still doesnt work. How difficult is it to get at the starter motor without hoisting the vehicle?
Post #711667 10th Jun 2018 12:29am
4RF RDS
Very easy, no issue at all. Just lay under it to undo the pos wire(s) and to get at the bottom bolts. The top 15mm is the PITA. You’ll need a couple different length extensions to get to it and you’ll only be able to turn is a 1/4 turn at a time. Remove the engine sound cover to make it easy.
Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #711668 10th Jun 2018 12:52am
