![]() | Home > Tdi > "P" gasket replacement |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
When I did my p gasket I used a genuine metal gasket and put a thin smear of wynns instant gasket on it. That was 4 years ago and no issues so far.
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 512 ![]() ![]() ![]() |
^^ Exactly as I did and been fine since
![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
^^ As above too. Have replaced two p gaskets (on different engines) this way with no problem . Also replaced water pump at same time as it was all stripped down.
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
Yep and me , do the pump at the same time
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
Thanks for the replies. I will also be replacing the pump
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 632 ![]() ![]() ![]() |
Did you find any of the threads had stripped?
I’m considering if I need to get a metric helicoil kit before I start stripping it down. 1995 Defender 110 CSW 1971 SIIA Lightweight |
These days I try to be prepared. I have already installed 2 on the timing cover and 3 on the exhaust manifold studs.
Seems LR don't believe in torq wrenches. I have both a 8x1.25 and 10x1.5 helicoil set in my garage. |
