Home > Tdi > "P" gasket replacement
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
So I'm going to be replacing the "P" gasket but I just wanted some feedback on one thing:
Should I just clean properly and use gasket as is.
Or
Should I apply a thin layer of some sort of sealer?
Post #710555 3rd Jun 2018 7:43am
Alex1976
When I did my p gasket I used a genuine metal gasket and put a thin smear of wynns instant gasket on it. That was 4 years ago and no issues so far.
Post #710556 3rd Jun 2018 7:46am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
^^ Exactly as I did and been fine since Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #710569 3rd Jun 2018 8:55am
Balvaig
^^ As above too. Have replaced two p gaskets (on different engines) this way with no problem . Also replaced water pump at same time as it was all stripped down.
Post #710571 3rd Jun 2018 9:25am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Yep and me , do the pump at the same time
Post #710611 3rd Jun 2018 5:04pm
jfh
Thanks for the replies. I will also be replacing the pump
Post #710723 4th Jun 2018 1:11pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Did you find any of the threads had stripped?
I’m considering if I need to get a metric helicoil kit before I start stripping it down. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #717618 14th Jul 2018 8:25am
jfh
These days I try to be prepared. I have already installed 2 on the timing cover and 3 on the exhaust manifold studs.
Seems LR don't believe in torq wrenches.
I have both a 8x1.25 and 10x1.5 helicoil set in my garage.
Post #717621 14th Jul 2018 8:36am
