Home > Maintenance & Modifications > Soft A bar - captive nuts |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
if its the top one in the photo then Id cut or grind the head off, remove the bracket and then you can see what you have got in terms of the captive nut, if the whole lot is turning then drill it out and fit the next size up. DEFENDER 90 TDCI XS,
30th May 2018 5:59pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 355 |
It is the top one.
The optimist in me was hoping for a less drastic fix. Keith |
30th May 2018 6:43pm |
sometimes applying a lever such as a screw driver in the gap will create enough friction in the right places to allow the fixing to release but that looks pretty rusty DEFENDER 90 TDCI XS,
30th May 2018 7:01pm |
I'm sorry to say, I've found when captive nuts in plastic start spinning you can't do a lot with them. If you try drilling them out the heat from the drill melts the plastic and makes the captive nut spin even more. Plumbers freeze spray on it every so often while you're drilling might work, but I've never actually tried it.
30th May 2018 7:50pm |
I may have a way to get my lightbar bracket mounted without removing the plate.
Would have preferred to buzzweld it first. Keith |
30th May 2018 9:55pm |
