Home > In Car Electronics > Ghost in the Machine......well, the radio/CD player
hursthouse
I hope someone can help me. Currently on holiday and found that my radio keeps switching itself on?! I have 2009 Defender 110 with a basic LR radio/CD player. I realise there is this ‘one hour on’ feature which means it switches itself off after an hour to avoid the battery being drained. However, I imagine that is if you accidentally left it on. Mine keeps switching itself on! I can’t tell how regularly it is doing it but I am worried I will have a flat battery by the end of the holiday. I keep having to go back to the car to check if it is on and regularly it is. I have tried switching it off in various ways - without touching the ignition and trying by turning the ignition on and then switching it off. Neither seems to stop the Ghost in the Machine! Can anyone help? To be honest the CD player doesn’t work properly either as it only occasionally lets you put a CD in (most of the time it doesn’t accept them in) so maybe the solution is a new unit all together as I get the feeling the LR ones aren’t great?
Many thanks in advance,
Stephen
Post #709980 30th May 2018 5:45pm
Greyman110
Can't really help with the problem but for the short term maybe pull the fuse for the radio? At least you won't have to worry about a flat battery then.
Post #709985 30th May 2018 6:20pm
stanley
There has been lots of things like this with the old style radio’s mine kept changing channels on its own , I upgraded to an alpine cdbt 133 as it was a straight swap
Post #709986 30th May 2018 6:20pm
seriesonenut
Hi
I picked up a 110 usw last September and thought I was going mad. Radio on during the night, or when we came back to it after parking up. The dealer changed the unit and showed me a stack of radios with the same fault - all out of Defenders! 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #709996 30th May 2018 7:11pm
hursthouse
Thanks everyone. At least it isn’t just me!
Greyman, can you tell me where to find the radio fuse? Sounds like a sensible solution for the time being.
Seriesonenut, when you say you took it to the dealer and they changed it - was that the dealer you bought it from or did you take it to a Land Rover dealer? I bought mine privately but if I could take it to a Land Rover dealer to get it swapped out because it is faulty then I will do that. That might be too much to hope for!
Cheers.
Post #710083 31st May 2018 7:47am
Greyman110
Sent you a PM with fuse box layout.
Post #710165 31st May 2018 3:10pm
seriesonenut
Hi
Independent dealer I am afraid. The cost of anew head is not too steep, however I went back within the 3 months I had an opportunity to and to be fair no question, just done. 2010 XS USW
Post #710183 31st May 2018 4:52pm
