Home > Maintenance & Modifications > Sealing the corner of window seals
mark13
United Kingdom 2004 Defender 90 2.5 TD HT Cairns Blue
I am currently swapping the external weather seal on the front doors of my 90 and want to seal the corners as it is a known source of water ingress. DumDum was always the preferred option but you can no longer get it, can anybody recommend an automotive water proofing black putty like substance?
Post #709562 28th May 2018 12:46pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Im doing the same thing and I've useBlack Tiger Seal.
Whether thats thje correct stuff i don't know but done the job
Post #709565 28th May 2018 1:25pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Post #709574 28th May 2018 2:55pm
NickMc
Black butyl sealant non setting is what you want. The 3M stuff is good but expensive Bow down don’t use tiger seal you’ll never get it apart again!
Post #709579 28th May 2018 3:15pm
zsd-puma
Unibond do one, available in most DIY shops as "guttering sealant" Wink
Post #709585 28th May 2018 4:01pm
