Home > Off Topic > Toylander accelerater from mobility scooter? How |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
Normal pedal with a loop on the top to hook with your foot and pull for reverse? 2002 90 Td5 Station Wagon
28th May 2018 6:36am |
Ignore the rubbish drawing on my phone but this is the thought I was trying to get across.
Loop or similar on the top perpendicular to the pedal face. Press the pedal for forwards then slide your foot up slightly and pull for reverse Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th May 2018 6:40am |
Another option as it's only a 3 wire potentiometer is a single pole double throw switch (cue another poor phone drawing ) 2002 90 Td5 Station Wagon
28th May 2018 6:44am |
Click image to enlarge Edit: Actually, that might not work if it's a dead centre pot. It would need to be slightly different. Click image to enlarge This second one is what you'd need for selectable forward and reverse. You send the forward signal from the forwards portion of the potentiometer to either the forwards for reverse portion of the controller depending on which wire you send the signal down 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th May 2018 6:46am |
Toylander club site
https://www.google.com/search?q=Toylander+...Mfw653giM: |
28th May 2018 7:02am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3790 |
Hello
Thanks for this, The idea is to cut the reverse part of the lever off and then fit a on / off / on switch to engage reverse. I'm not idea how to do this yet... However I've started making the pedal to make it go and The dashboards looking something like... Click image to enlarge then the pedal... Click image to enlarge so the switch I have to engage reverse is like this, but how do I wire this to what would have been reverse on the handlebar (so the three wires coming out of the pedal mechanism. Thanks |
29th May 2018 10:19am |
Can anyone help with how I wire this?
Thanks |
30th May 2018 7:46pm |
Bauwe Member Since: 10 Mar 2024 Location: Gelderland Posts: 1 |
Hello everyone,
I am currently building a Toylander 90. I would also like to use a normal foot pedal where I can select the reverse position with a switch, can you help me with this? It has already been discussed above, but can you explain it a little more or go into it a little deeper? I use potentiometer with 3 connections. Friendly thanks |
10th Mar 2024 11:33am |
