Home > Defender Celebration Series & Classic Works > Adventure Interior
Page 4 of 4 <1234
SkyFallSilver
Kuwait
Rear Turn Signals done in Perei LED to match the rest of OEM lights, surprised why LR would keep this in non LED.
In hand oem vs Perei installed
 2016 Defender 90 Adventure Edition
Post #707520 16th May 2018 2:50pm
NMBRPL8
Australia
Good work.
Are the Perei unit a plug and play job?
I note the adventure retained non-led ancilliary lights at the front end, too.
Post #707610 17th May 2018 2:02am
ericvv
Sky, well done. You can now also swap the turn signal and rear fog light, respectively reverse light, around. That way you have the lights in the correct position like any other standard Defender. I did this on the SVX, plug ‘n play. Reason why Land Rover never installed a Le Perei LED turn signal was that they would then have had to use a different relay than on standard Defenders, so an extra part (cost) again. And reason why they put them on the inside position of the truck is just looks. Someone there when this was first done on the SVX decided that the regular bulb fitted turn signal lamp under the Le Perei LED tail/stoplight would look odd. That’s why they moved the LED rear fog/reverse lights to the outside position.
The SVX type front turn signals also exist in a high quality LED version (Hella), available in a plug ‘n play version from site sponsor Mobilecentre. I just have not been totally convinced by those (yet Whistle ), especially since I keep my full halogen front lights set up. For the Adventure with its Nolden these Hellas make more sense possibly. Getting expensive ideas here again I feel. Rolling Eyes Laughing
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #707612 17th May 2018 4:46am
SkyFallSilver
Kuwait
Thanks for the tip,
Keeping it the way it is, their jammed into the plinth Smile
Doesn't harm me having them in factory location.
Just installed LED license plate light as well looks cool with the white. 2016 Defender 90 Adventure Edition
Post #707828 18th May 2018 12:32am
ericvv
Post #707832 18th May 2018 6:00am
SkyFallSilver
Kuwait
Its Wipac I like how they look now, will be tackling the audio system soon by installing an Alpine Amp & Subwoofer. 2016 Defender 90 Adventure Edition
Post #709279 26th May 2018 10:27am
Page 4 of 4 <1234
