![]() | Home > Defender Celebration Series & Classic Works > Adventure Interior |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Rear Turn Signals done in Perei LED to match the rest of OEM lights, surprised why LR would keep this in non LED.
In hand oem vs Perei installed ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2016 Defender 90 Adventure Edition |
Sky, well done. You can now also swap the turn signal and rear fog light, respectively reverse light, around. That way you have the lights in the correct position like any other standard Defender. I did this on the SVX, plug ‘n play. Reason why Land Rover never installed a Le Perei LED turn signal was that they would then have had to use a different relay than on standard Defenders, so an extra part (cost) again. And reason why they put them on the inside position of the truck is just looks. Someone there when this was first done on the SVX decided that the regular bulb fitted turn signal lamp under the Le Perei LED tail/stoplight would look odd. That’s why they moved the LED rear fog/reverse lights to the outside position.
The SVX type front turn signals also exist in a high quality LED version (Hella), available in a plug ‘n play version from site sponsor Mobilecentre. I just have not been totally convinced by those (yet ![]() ![]() ![]() Eric ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks for the tip,
Keeping it the way it is, their jammed into the plinth ![]() Doesn't harm me having them in factory location. Just installed LED license plate light as well looks cool with the white. 2016 Defender 90 Adventure Edition |
Wipac? You never actually own a Defender. You merely look after it for the next generation.
Its Wipac I like how they look now, will be tackling the audio system soon by installing an Alpine Amp & Subwoofer. 2016 Defender 90 Adventure Edition
