![]() | Home > V8 > 14 CUX Speed sensor |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 924 ![]() ![]() ![]() |
Yes I took a T off the speedo wire to provide a speed signal to the ECU when I built my 90 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2307 ![]() ![]() ![]() |
That's cool Devon-Rover, so the Defender transducer gave the right signal to the ECU ?
MO The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Yup.
I swapped the disco 1 transducer for the TD5 defender one as I had the td5 defender dash fitted mainly because the NAS speedo cable and remote Speed sensor was NLA. From my experience the 14CUX system from my 90 build doesn't want to see an exact number of pulses just a form of signal and It'll hold the higher Idle revs so you don't get the stalling and fluffing about you see on the ones where the speed sensor is unplugged and for example when you come off the throttle and brake to a halt at traffic lights. It held the raised revs until I stopped and then the IACV stepped the idle down lovely. ![]() |
Brilliant, many thanks Devon-Rover
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 150 ![]() ![]() ![]() |
Thats useful to know, thanks!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
I agree... when I had a 3.9 EFI in my old 110 hicap, prior to fitting the speed transducer it used to stall all the time when coasting to a stop.
Fitted the transducer and it stopped it. Mine had the old mechanical speedo, so I just got the cable to attach to the transducer to speedo head (think it was a 110 NAS part... I've got the part numbers somewhere) |
