Home > V8 > 14 CUX Speed sensor
Mo Murphy
14 CUX Speed sensor
I'm putting a 3.9 14 cux V8 in my 90 shortly.
I'm using TD5 instruments and YBE100530 speedo transducer. Will the transducer produce a suitable signal for the 14 cux ecu ? The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #693271 14th Mar 2018 2:25pm
Devon-Rover
Yes I took a T off the speedo wire to provide a speed signal to the ECU when I built my 90 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #693355 14th Mar 2018 7:35pm
Mo Murphy
That's cool Devon-Rover, so the Defender transducer gave the right signal to the ECU ?
MO The Land Rover 90 - Many are called, few are chosen.
Post #693356 14th Mar 2018 7:41pm
Devon-Rover
Yup.
I swapped the disco 1 transducer for the TD5 defender one as I had the td5 defender dash fitted mainly because the NAS speedo cable and remote Speed sensor was NLA.
From my experience the 14CUX system from my 90 build doesn't want to see an exact number of pulses just a form of signal and It'll hold the higher Idle revs so you don't get the stalling and fluffing about you see on the ones where the speed sensor is unplugged and for example when you come off the throttle and brake to a halt at traffic lights. It held the raised revs until I stopped and then the IACV stepped the idle down lovely.
Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #693369 14th Mar 2018 8:06pm
Mo Murphy
Brilliant, many thanks Devon-Rover Thumbs Up
Post #693370 14th Mar 2018 8:14pm
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
Thats useful to know, thanks!
Post #708774 23rd May 2018 2:17pm
I agree... when I had a 3.9 EFI in my old 110 hicap, prior to fitting the speed transducer it used to stall all the time when coasting to a stop.
Fitted the transducer and it stopped it. Mine had the old mechanical speedo, so I just got the cable to attach to the transducer to speedo head (think it was a 110 NAS part... I've got the part numbers somewhere)
Post #708831 23rd May 2018 8:21pm
