Home > Maintenance & Modifications > Ramps
Page 1 of 4 1234>
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Ramps
Sorry if this is a dumb question and it’s been done to death, but what ramps do I need for getting under a 110? I ‘fancy’ doing some DIY Dinitrol-ing this summer. (I don’t want to die though)
Post #708522 22nd May 2018 5:32am
zsd-puma
A couple of bits of railway sleeper work fine. You don’t need to lift a defender far to make lots of room underneath.
Post #708539 22nd May 2018 6:48am
Doc P
Thumbs Up - never thought of that!
Post #708543 22nd May 2018 7:19am
grafty99
Or for easier storage and manoeuvring on your own - four 6 inch breeze blocks with some 4 × 2 timber to make them easier to drive up Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #708544 22nd May 2018 7:23am
grafty99
Sorry, missed the bits part of railway sleeper Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #708545 22nd May 2018 7:24am
I was brought up in the school that believed you should never use breeze blocks, bricks, or any material like that, since they they can crumble and kill you. Timber is good, however, since it doesn't crumble.
It is useful for many purposes to have a supply of sawn blocks of regular size to build cribbing.
Post #708559 22nd May 2018 8:31am
X4SKP
Hello Doc P
I agree with the comments so far...
For general 'easy to get under work', I took 4 'standard' Metal Ramps,
added some extra metal work, base level cross elements to prevent splaying
and to allow the metal ramps to engage with wooden base blocks, these also
'grip' better on our gravel hard standing area.
On top of these Ramps I added wider run up ramps, which were old Pipe transporter
spacers, which add a little extra height and help with the 'progressive' drive up...
stop at the 4th indent!
I went the extra step when applying Dinitrol of lifting the Defender off each Ramp,
reversing the rear two Ramps so that they face inwards (matching the front Ramps)
then resting the whole Land Rover on a combination of Oak Sleeper Blocks and 4 smaller
Oak Blocks 'profiled' to engage with the Axle load points.
Over all this raise the Defender just short of 0.5M and with carful placement of all elements
the only real movement was within the suspension elements.
Good Luck... SKIP
Post #708562 22nd May 2018 9:02am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
^ That looks.... scary!
Best be safe and do it properly:
[/img]
Post #708572 22nd May 2018 10:25am
X4SKP
back at you... Shocked
(your's is worse than mine... Thud) SKIP
Post #708573 22nd May 2018 10:34am
Ads90
Laughing I'm guessing that's the automatic jacking feature in the event of hub failure? All ready to work on. Very clever.
Post #708576 22nd May 2018 10:54am
X4SKP
auto jacking is possible...
 SKIP
Post #708578 22nd May 2018 11:01am
zsd-puma
Yes whole ones are somewhat heavy. Laughing Although if you had space you could build a permanent ramp out of them. even double stack them.
A couple of bits about 2ft long do the job well. If you cut them with the chainsaw at a 45 degree angle it gives you two bits with a nice lead up ramp.
The problem with the drive up metal ramps is the stop bar at the ends of them isn't really big enough for a Defender, so there is a risk you'll drive straight off the back of them.
Post #708601 22nd May 2018 2:27pm
zsd-puma
You could probably use concrete padstones to 'drive' on to. They won't crumble, they're designed to rest RSJ's onto, it's more likely your drive way would crumble under them. But then again they're really heavy and expensive compared to wood so what's the point.
I'd never use concrete as an axle stand though, the concentrated pressure could easily split the concrete.
Post #708603 22nd May 2018 2:37pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Some spare wheels/tyres and some bridging ladders to drive up ?
 http://www.yorkshireoffroadclub.net/
Post #708611 22nd May 2018 4:16pm
Craig-C
United Kingdom 2007 Defender 90 Puma 2.4 HT Rimini Red
[/img]
This is a the father in law doing his maintenance many years ago. Just a spade under the tyre. Not recommended Shocked
 FFRR TDV8 sold
PUMA 90 :0[==]0:
90 TD5 CSW XS
MX5 (NC)
BMW 320
BMW 1200 GS Adventure
SUZUKI HAYABUSA
Post #709377 26th May 2018 9:43pm
Page 1 of 4 1234>
