Home > Puma (Tdci) > New Member - 110SW with 2.4 Build |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
Afraid I can't help with the questions but welcome to D2N James
18th May 2018 9:10pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2416 |
Click image to enlarge Since you are there, I suggest you to check the clutch assembly as some past parts are made of cheese. Actually still. It is a cheap and poor design. Puma 110" SW ............................................................. Earth first. Other planets later |
18th May 2018 10:22pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Is the chassis galvanised or is that bare steel on the engine mount? Either way it's poor painting
19th May 2018 10:22am |
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 67 |
Thank you will check these items. |
19th May 2018 4:10pm |
Galvanized Chassis - The paint is only in areas that can be seen once the truck is back together - I do not like the look of a silver chassis. I would have preferred to powder coat the chassis prior to assembly, but i wasn't going to tear the entire roller down just for that. |
19th May 2018 4:14pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
The heater pipe area is the most congested, have you got the bracket for it’s control valve that mounts to the engine? I would fit all of it too and check for clearances on the hoses, your hoses are aftermarket so I’m sure they don’t have the alignment marks like the original hoses. If you have them it might help you out the white “paint” marks.
Your oil cooler hose might be upside down or the one at the “Y” on the water pump? and iirc the two pipes over the bellhousing go higher? |
19th May 2018 6:35pm |
NickMc - The bracket you mentioned - is it the one that mounts to the bulkhead and holds the white valve? If this is the one you mean then yes I do have it but the bulkhead has not been mounted on the frame yet as I am refurbishing it and adding A/C and switches etc.
No I do not have the alignment marks and I did my best to match up the old hose setup. The two pipes at the bellhousing with shift up once the hoses are connected to the valve from what I can tell plus there is a clip on the valve to keep them up higher if I recall correctly. Thanks - Mark |
29th May 2018 8:11pm |
