Home > Td5 > Fuse problem
defsan
Netherlands 2007 Defender 110 Puma 2.4 SW Java Black
Fuse problem
Hello all,
Posting from southern france Very Happy we are making a small trip around France and now fuse 8(signals, instrument etc) decides to pop all the time when I turn the key.
Have checked and cleaned the Ecu but to no avail, any ideas? Big Cry
Warnings lights works
Regards,
San
Post #707933 18th May 2018 5:34pm
mk1collector
Try unplugging the tow bar electrics under the right rear wing behind the rear lights, it's a grey plug. Ray
My build thread
Post #707936 18th May 2018 5:48pm
defsan
Hi Ray,
Thank for your reply, could it be that someone soldered it instead of the plug?
This is what i am seeing!
Post #707937 18th May 2018 6:00pm
mk1collector
If you follow the wires from the back of the tow electrics up behind the plastic shield you should find the plug, directly behind the light panel. Ray
My build thread
Post #707943 18th May 2018 6:25pm
mk1collector
Trying this is just to rule out any damp or corrosion in the tow electrics so if it doesn't solve the problem then just plug it back in. Thumbs Up Ray
My build thread
Post #707945 18th May 2018 6:27pm
defsan
Unfortunately they go directly from the towing connecto to the displayed wire harness.
There is no connector to be found Neutral
Post #707947 18th May 2018 6:32pm
mk1collector
In that case try cleaning out the tow socket and see if it make a difference. Ray
My build thread
Post #707950 18th May 2018 6:40pm
mk1collector
As the wiring looks like it's been wrapped in insulation tape it may be worth thoroughly checking it for splits and maybe moving the tow electric loom about (bending here and there ) to see if it cures your problem. If it does it could suggest broken or touching wires in the wrapped loom. Ray
My build thread
Post #707951 18th May 2018 6:45pm
mk1collector
IT would be worth checking the indicator bulb holders for moisture and corrosion too. Ray
My build thread
Post #707956 18th May 2018 7:08pm
defsan
Already checked 3 of them, seem to be okay.
Else the fuse would blow too with the hazard lights on right?
Post #707962 18th May 2018 7:17pm
dorsetsmith
Alarm ECU and Battery back sounder for 02 onwards fuse 8
Post #707976 18th May 2018 8:11pm
defsan
Many thanks everybody for the suggestions, checked all but seems there is a direct short somewhere which I am
Unable to trace Sad
Post #708058 19th May 2018 11:57am
mk1collector
Hopefully someone else will come along with more ideas Thumbs Up hope you get it sorted. Ray
My build thread
Post #708060 19th May 2018 12:06pm
defsan
Thanks!
Post #708063 19th May 2018 1:03pm
dorsetsmith
fuse 8 signals, instrument etc) Question in td5 signals are fuse 7 . 3 1999 to 2001 and
2002 to 2006 fuse 31 & 21 Question
Post #708066 19th May 2018 1:27pm
