![]() | Home > Puma (Tdci) > power loss. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi BigMike!
Same problem when towing a 1.3 ton trailer in a slope under warm conditions. Appears to be a protection system but not 100% sure. http://www.defender2.net/forum/topic5764.html?highlight= Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Mike, how much do you trust your OBDII reader? If you trust it discount the thermostat as the sensor monitors the cylinder head coolant temp. If you don't trust it swap out the thermostat as the ECU will put the engine into safe mode once it reaches a certain temp to protect the engine.
cheers Ed, I read your post, keep us updated.
Bri, it's definitely going into safe mode. under heavy load it does it for 2 seconds at a time before power comes back. if the load is still present, 2 more seconds etc etc. Seems that in the 2 seconds the temp drops enough to come out of safe mode, but then goes back in if the load is constant. not sure I understand your post - my OBD reader is definitely accurate. do you mean change the thermostat for a new one? |
Yes Mike sorry, replace the thermostat. As the thermostat only opens when the engine reaches operating temperature that would be the first thing I would check/ replace ( but if you trust the readings you are receiving then it wouldn't be the thermostat as the cylinder head sensor would show a higher temp reading if the thermostat wasn't working properly
ah gotcha. will do, cheers
Right. It's not the cooling system, have eliminated that.
Had a long discussion yesterday with Lee skip, senior mechanic at Lakeland Landrover and he tells me he gas seen this on three other vehicles and it's the fuel filter housing being partially blocked. Changing the housing resolves it so he tells me. He also mentioned that he knows LR is aware if it and are looking at it. |
So an update (am I talking to myself?
![]() problem is either the high pressure fuel pump or the transfer pump, they've havent worked out which yet, but that's the answer which has been given to me this morning. For anyone else who has this issue, as a reminder, there are no fault codes exhibited by the ECU. Very frustrating when you look after your vehicle to the best of your ability with frequent oil changes, cleaning the underside, waxoyling and general servicing etc. |
Thanks BigMike for the update.
In our case the problems only happened 3-4 times during towing and never more. I will check the fuel filter housing. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
You're definitely not talking to yourself - keep us updated.
Presume you've read this already Mike
robharvey wrote: There are quite a few of us having this problem in South Africa. Mine cuts power in 30+ degrees ambient, going up hills at altitudes over 800m. This is a known issue, I had a chat with the Technical chap at LR N1 City about this: Quote: We found on some cars that the wires on the turbo modulator plug pull out due to stress on the loom or engine vibrations. So they move the ferrite further down the loom. So if there is issues with the pins on the plug you must renew the plug with pins. The old loom/plug had a ceramic part that prevented 2 metal parts from touching, this was more evident in high ambient temps. The new loom/plug does not contain the ceramic part, this even in high temps the metal parts are able to touch. or something to that effect, but if you phone N1 City and ask to speak to Fanie, he knows what this is. He checked mine and found the new loom/plug (Jan 2010 model). Original Member Pie n Pea Club. 110 HCPU Tipper |
Cheers Pete - been talking to rob on pm's
I suppose last thing would be to get it to the stage where the power loss starts to happen hook up a test system ( BAS or alive can do this) drive and record live what happens when the power loss occurs. Original Member Pie n Pea Club.
110 HCPU Tipper |
I'll be doing just that if this doesn't resolve it.
BigMike
Have you got your Defender back yet? If so which parts did they replace (and why, if they told you)? |
