Home > Maintenance & Modifications > Dinatrol results 18months later
Page 2 of 4 <1234>
mick
Yeh who do we need to avoid obviously get in touch with them 1 st give em a rolloking then tell us.
Post #707297 15th May 2018 12:30pm
jst
I was thinking of doing mine myself or getting it applied this summer who did yours I don't want to go to them Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #707304 15th May 2018 1:17pm
MartinK
Personally, having read the threads on the subject, I would DIY (as I did) or go to Zagato... Lots of problems/issues apparent with other suppliers... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #707305 15th May 2018 1:19pm
Sulisuli
I guess the OP may have just posted to gauge people’s opinions on the quality of workmanship to see if that’s the norm with a Dinitrol application, perhaps he may wish to deal direct with the company to get a resolution rather than going the “name and shame” route, his choice at the end of the day and if he wishes to say who did the work again his choice. Just my thoughts on the subject Whistle 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #707357 15th May 2018 6:03pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Another vote for Zagato. Thumbs Up
Just been out to check on the condition of mine, which is now 3 years since it was done, used daily in all weathers, and it still looks great. Odd little spot here and there but nothing to be concerned about 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #707505 16th May 2018 12:59pm
ericvv
We here in La Suisse get a real working 3 year warranty on Dinitrol treatment. Condition obviously is that application is on a new chassis, or at least on a very recent chassis which still is totally rust free and clean. Mine will be 10 years come September, it had so far an ititial application, plus two resprays in that period. Last respray was now 3 years ago, so it will go back for another respray this summer. The interesting thing is that the cost of a first class professional high quality treatment, nothing less than what Zag(ato) does, costs even less here in expensive (?) Switzerland than many poor workmanship applications in the U.K. Now, if you start from a already (even surface) rusty chassis and then without a very thorough preparation to first neutralise all rust, I can imagine that even a very thorough Dinitrol spray ain’t gonna do wonders.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #707515 16th May 2018 1:31pm
cecilthecat
I'll cast my vote for Zagato to as mine it also 3 years old and looks pretty much the same as the day he did it although with a bit of dirt now but no rust Smile
Post #707517 16th May 2018 1:37pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Having done Dinitrol to 5 different Defenders I can certainly say it would be easy to do a quick shoddy job that may look nice when it's first complete.
To be done properly, it takes hours of detailed and monotonous work. The washing and prep work has to be meticulously done, you have to have patience, and do the entire underside with consistent detail. (consistency is a big key).
In a similar way to body and paint work, the end result is directly related to the quality of the prep work that lies under the final finish, as well as the quality of the spray coats. There are a lot of "out of the way" spots on the underside that are difficult to clean and spray, which can go un-finished, and are difficult to see by just bending over and looking at the undercarriage.
Like picking a body / paint shop, ask for referrals and take a close look at several of the vehicles they have previously done, not ones just recently finished but one, two or three years along.
The devil is in the details...
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #707539 16th May 2018 3:46pm
Lotus_esprit_s1
Thats some pretty abysmal welding by GKN on the rear crossmember closing piece!
Post #707586 16th May 2018 8:29pm
zsd-puma
I think abysmal would be having it porous with poor penetration, so it's weak. That isn't especially pretty, but I'm not sure I'd call it abysmal, especially as you can't see it unless you lay on the floor. For someone doing a one off job you'd grind it down and clean it up, but it's not especially unusual for a mass produced item.
Post #707609 17th May 2018 12:38am
sewin elwy
Wales 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
bpman wrote:
so, who is going to ask first ?
(elephant in the room)
This is a problem and having been involved with land rovers since 1975 I have reached the conclusion that this problem is due to chassis prep prior to painting, like most LR bolt=on's in fact! they are often rusty or covered in oil based protection and are not cleaned well enough for paint to stick! they're all good to look at when new but if it sheds the paint it will shed your rust treatment too!
Over the years I've seen chassis' that are excellent and others that look awful at two or three years old regardless of preventative treatment. Don't despair, yours looks solid and now is the time to rectify. It needs extreme jet washing to clean and remove all lose material, fully dried and then treated with the product of your choice ( don't want to start a row over the options so ill leave it to you) you'll find the result will be much better this time!
Last piece of advice, use a light ultra penetrative option first that will creep into all the joints and give it a chance to settle and creep before applying the tougher final covering. Good few days is best!
Hope this helps and yes it really isn't good enough is it. hit and miss like a 70's Friday night car should be well in the past!
Post #707771 17th May 2018 6:59pm
familymad
Dinatrol assessed the vehicle and reported back :
“It does not look good. It is usually Rejel Automotive who has contact with the treatment centres, Phone: 01234 273388.
The best way to protect a chassis is to use Dinitrol ML in the cavity and as a primer for Dinitrol 4941 underbody protection. The most important thing about using Dinitrol 4941 is that it should be applied in a layer of 500-700µm. Based on the pictures you have submitted, it appears that this is not the case.
You should contact %@%# and ask for an explanation”
I have received a full refund for the work and won’t post on here who the supplier was. I’m hopeful of giving them a second chance at proper preparation followed by a correctly applied treatment. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #707913 18th May 2018 2:28pm
Sulisuli
Great news you got resolution and it’s alsorted for you Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #707917 18th May 2018 2:50pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
mines not to good after 2 years after seeing a few marks around the rear chassis , I did a bit of scraping and found rust under the coating .
Post #735964 20th Oct 2018 8:37pm
LR90XS2011
did mine myself when 1 month old its now 7 years old and pretty much looks as good as the day I did it,
I was very careful to ensure it was totally clean and totally dry before I did it. To be fare I have only done 24k mikes and not done any real off road stuff . DEFENDER 90 TDCI XS,
Post #735989 21st Oct 2018 5:30am
Page 2 of 4 <1234>
