Home > Technical > Let's talk about my nuts....
Grenadier
Have just gutted the DC, including removing the dash and lifting out the transmission cover etc, all in aid of a number of jobs to prep the Def until the next big strip out, hopefully no less than a decade away. I'm keen to lift the floor panels up, to give them a good clean before sound-proofing, sealing and re-fitting, but as Mrs Grenadier is unlikely to find herself under the chassis, and my arms are not as long as Mr Tickle's, I cannot work out how to remove the bolts towards the transmission tunnel or mid-point on the rear passenger floor panel. Does anyone have a clever trick (or recommend a tool) to hold the nut in place under the panel, whilst undoing the bolt from the top? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #706598 11th May 2018 4:48pm
mk1collector
I thought they were just screwed down into plastic clips? Ray
My build thread
Post #706601 11th May 2018 4:57pm
I can't remember if you actually need to, as I think they're captive.
But anything that involves tickle arms and you're spannering solo, climb underneath and clamp some mole grips on offending nut, the chances are it'll turn and wedge on something and hold the nut for you.
Post #706602 11th May 2018 5:01pm
Grenadier
Mine don't seem to be. Hex bolts all round. But then having stripped this back, a lot is not what it seems (or the stealer claimed it) to be. Lucky I bough the DC with the intention of fully stripping it back and eventually re-doing everything from the ground up. But some of the DIY stuff under the skin is frankly laughable. And I bought from the stealer because I thought they had a good reputation... Monsieur Le Grenadier
Post #706603 11th May 2018 5:03pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I've taken mine apart a couple of times and it was screwed into plastic clips with fat self tapping screws. Same type as the front grill.
Post #706608 11th May 2018 5:31pm
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
The grinder is your best friend here, whip off the tops and punch em through
Post #706612 11th May 2018 6:04pm
UtilityTruck
I had to resort to the neighbours help when I fitted my rear mud shields- I simply couldn’t get the nut onto the screw and hold the top of the screw all at the same time.
A gizmo would be useful, but not sure how you could do it. 2014 Keswick Utility 2.2
Post #706615 11th May 2018 6:24pm
