![]() | Home > Td5 > TD5 central locking and interior lights. |
That suggests that the car thinks that one of the doors is open. Check the condition of the door switches and their wiring for chaffing that's allowing a path to earth. Darren
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
I'd check the wires on the door switches first, they tend to go brittle and snap/short. This would cause the interior light to remain on and the alarm to toot when locking the vehicle.
edit - beaten to it ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
Thanks
I will check the door switches and report back. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Are all doors properly closed? The hoot when locking means that one of the doors or bonnet is open, so it's likely that you have an issue with one of the contacts in the doors.
Maybe check that nothing has become loose. Don't know about the rear doors, (I have a hardtop, so 2 doors only) but you can easily remove the front door switches from the bulkhead , takes only 1 screw. A single cable should be attached to them. You can start by pushing them first and see if anything happens. Greetings, Joris |
Thank you both for your input the rear door switch was missing its plunger.
I had a look at the other door switches which were also pretty corroded I have ordered a set of 3 to replace them. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42 ![]() ![]() |
I had the exact same problem 18 months ago. New door switches all round and been fine since.
