Home > Td5 > TD5 central locking and interior lights.
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I am looking for advice on this one.
Whilst driving my TD5 XS my interior lights came on and remained on until physically switched off.
When I parked the vehicle and operated the key fob for central locking /Alarm activation the vehicle horn tooted twice and there was no flashing of indicators as I normally have and the doors locked.
When operating the fob to open the car the doors opened and the indicators flashed as normal.
I have looked through the handbook but did not find any solutions in it. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #706551 11th May 2018 10:10am
That suggests that the car thinks that one of the doors is open. Check the condition of the door switches and their wiring for chaffing that's allowing a path to earth. Darren
Post #706554 11th May 2018 10:25am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I'd check the wires on the door switches first, they tend to go brittle and snap/short. This would cause the interior light to remain on and the alarm to toot when locking the vehicle.
edit - beaten to it Laughing 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #706555 11th May 2018 10:27am
MJN110
Thanks
I will check the door switches and report back. 2016 Defender Landmark 90
Post #706556 11th May 2018 10:28am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Are all doors properly closed? The hoot when locking means that one of the doors or bonnet is open, so it's likely that you have an issue with one of the contacts in the doors.
Maybe check that nothing has become loose. Don't know about the rear doors, (I have a hardtop, so 2 doors only) but you can easily remove the front door switches from the bulkhead , takes only 1 screw. A single cable should be attached to them. You can start by pushing them first and see if anything happens.
Greetings,
Joris
Post #706557 11th May 2018 10:31am
MJN110
Thank you both for your input the rear door switch was missing its plunger.
I had a look at the other door switches which were also pretty corroded I have ordered a set of 3 to replace them. 2016 Defender Landmark 90
Post #706563 11th May 2018 11:45am
TD5Neil
I had the exact same problem 18 months ago. New door switches all round and been fine since.
Post #706637 11th May 2018 6:56pm
