![]() | Home > My Defender > hanks Double Cab |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
Great photos
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Looks awesome
![]() How was the job taking the axle off and re installing? Fox dampers are looking good too! How's the ride with them? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Dropping the axle is simple. I hadn't done it before and had the axle off within two hours.
Rather than disconnect the brake lines and having to bleed the calipers on refitting I leave the caliper connected and unbolt/tie up in the wheel arch, Then it's just a case of going round disconnecting things... - Radius arms - Panhard rod - Shock absorbers - Propshaft - Steering box drop link I disconnect the radius arms at the chassis end so that I can lower the axle down on a jack pivoting about their radius which seems more controlled to me |
Loving the pics, especially the one with the caddy.............but I may be biased
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Looking good Hank
![]() I thought you would like the caddy Ray ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
This evening's mod... Had one in the house so why not
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Thats awesome!!
What size strut? Where did you mount it. I must do this! |
Basically a Range Rover now
![]() Any feedback on those fox shocks? |
Sorry, completely missed your question on the Fox dampers! I can't comment on longevity yet but the build quality is second to none. They seem good, ride quality is greatly improved but that's more than likely due to original's being shot. Expecting the ride to improve again when I swap rear springs for a lower spring rate than the HD ones currently fitted.
Gas strut I had left over from another project but is identical to this ![]() https://www.ebay.co.uk/itm/191184708440 |
Fitted a new steering drop arm ball joint today. Frustratingly it’s a job I had previously done but when I replaced the steering box recently the nice new ball joint was lost.
So new genuine JLR ball joint kit fitted plus a slight tweak of steering box play adjuster and the steering is now absolutely bang on. No play whatsoever - it has really tansformed the drive! No more constant steering input along straight roads! |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Just ordered one of those gas struts
Couldn’t help myself ![]() |
Same here
Hank , I’m hoping to find time to tackle mine today Any chance you could give an idea of measurements for the pivot mounts positions please ![]() Cheers G My confidence has been writing cheques that my abilities can't cash for years. |
