Home > Puma (Tdci) > Mystery Button
gridge
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Belize Green
Mystery Button
Hi, I have just bought my first Defender which i love. i bought if from a Lady Who's husband had unfortunately died so the handover wasn't thorough.
i have been unpicking bits and bats, lights, fog lights, spots remote control lights etc etc but there is a mystery button on the dash, when you press it it goes green. i cant see anything that obviously happens when the button is green...
i know it could be anything, but can anyone suggest what it may be?
any answers gratefully recieved
Pete
Post #706349 10th May 2018 8:04am
Sulisuli
Pete a picture may help unravel the โ€œgreen buttonโ€ mystery for you. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #706351 10th May 2018 8:07am
Without a bit more detail it really could be anything from a winch isolator to a rear view camera, neither of which may no longer be fitted.. If you can post some pictures of the button and the vehicle generally then that may give more of a clue. Darren
Post #706352 10th May 2018 8:08am
Martin
Site Admin
gridge's photo:
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #706354 10th May 2018 8:10am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I wonder if it could be an ignition bypass, allowing you to remove the key with the engine running.
Post #706356 10th May 2018 8:28am
gridge
Clive, ill give that a go when i get home thanks for the suggestion.
Post #706358 10th May 2018 8:29am
Greyman110
Ha....I have a very similar thing on my car on the steering column! I took mine in for some work yesterday and put that on the list so if they find out what it is I'll let you know Very Happy
Post #706370 10th May 2018 8:58am
Zed
Ejector seat.
Post #706373 10th May 2018 9:06am
Portafilter
Australia
why would you do that? wouldnt you lock up the steering, among other dangerous things?
Post #706380 10th May 2018 9:39am
Clive
" ... why would you do that? wouldnt you lock up the steering? "
Yes, that's the idea, it allows you to leave the car unattended with the engine running while using lights/power etc, or just while warming up outside the house, the steering lock would render the vehicle virtually immobile.
I added my own version to a D3 I had, I linked it to the brake switch to disable the bypass and turn off the engine if the brake was pressed.
Post #706381 10th May 2018 9:52am
ibexman
Misiles ๐Ÿ™ˆ
Post #706383 10th May 2018 10:17am
Immmobile or not, if on a public highway or space though that would be illegal. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #706387 10th May 2018 10:57am
dorsetsmith
Rule 123
You MUST NOT leave a parked vehicle unattended with the engine running or leave a vehicle engine running unnecessarily while that vehicle is stationary on a public road. Generally, if the vehicle is stationary and is likely to remain so for more than a couple of minutes, you should apply the parking brake and switch off the engine to reduce emissions and noise pollution. However it is permissible to leave the engine running if the vehicle is stationary in traffic or for diagnosing faults.
Post #706392 10th May 2018 11:15am
hank
As said, could literally be anything! Obvious question but are there any aftermarket electricals on the vehicle? Like work lights, beacon etc
I suggest tracing the wiring. Whip off the fusebox lid under the steeling column (two quarter turn fasteners) and position your head down in the footwell looking up, see whether you can see any 'aftermarket' wiring
Report back, I'd be interested to know!
Post #706396 10th May 2018 11:24am
zsd-puma
Some utility company Defenders had them when fitted with a power take off, or hydraulic winch. So the keys could be kept safe while the operators were doing their stuff around/near the vehicle. So the vehicle wouldn't be running 'unnecesarily' or 'unattended'.
As for the green switch, this is just a generic after market switch, it could be for anything. All any of us can do is throw in random guesses, You'll just have to trace the wires and see where they go unfortunately.
Post #706425 10th May 2018 1:22pm
