Home > Td5 > TD5 Immobiliser
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
TD5 Immobiliser
Apologies in advance if what follows is moronic. I have a 2004 TD5 [farmer spec'] and when I turn off the ignition and remove the key, there is an electronic chirping sound - is this an immobiliser? I am a bit puzzled as the key is just a standard without any chipped fob. If it is an immobiliser, does anyone know what type? Thanks in advance.
Post #704002 29th Apr 2018 4:14pm
mpald
A bit of googling suggests there may be an immobiliser on the ECU that was never activiated; if so, any ideas why the chirp?
Post #704003 29th Apr 2018 4:18pm
dorsetsmith
10AS LR factory fitted
Post #704017 29th Apr 2018 5:49pm
mpald
Thank you - much appreciated. I have seen I can have it activated if I get some fobs - I may look into it.
Post #704036 29th Apr 2018 7:15pm
roel
My 2003 farmer spec 90 does not chirp and my standard startprevention is disabled so I am not sure if yours is completely standard.
 Roel
2003 90 Td5 (2009-now)
Post #704229 30th Apr 2018 6:01pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
may sound silly but some head units with a removable facia chirp when they are turned off to remind you to remove the facia. nobody is perfect but being Scottish is a start
Post #704394 30th Apr 2018 8:27pm
mpald
I shall give that a whirl as someone has replaced the head unit with one with a detachable facia - much appreciated to both.
Post #706092 8th May 2018 8:00pm
