Home > Td5 > Problem Starting |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
I recently began having problems starting my car. I just changed the fuel filter valves which did not make a difference. What else can it be? The fuel pump seems to keep pumping and after cranking over for about a minute, it may start. It seems like its taking longer to start everytime. Could it be the Injector seals?
7th May 2018 8:33pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
leaky injector seals are easy to identify... you'll get a fairly large cloud of black smoke out of the back when it does eventually start 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
7th May 2018 9:55pm |
That's what I'm getting!
8th May 2018 12:32am |
fairly easy fix then
Pay the extra for genuine seals. They seem expensive but the quality is worth it 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
8th May 2018 1:30am |
Do I have to remove the fan and also the rockershaft?
8th May 2018 3:33am |
Do I have to remove the fan ( yes) so you can get to crank shaft bolt and also the rocker shaft YES
have look at the link below http://www.discovery2.co.uk/Injector%20Seals.html |
8th May 2018 6:36am |
