Home > Td5 > Td5 aircon - uneven air distribution through vents |
td5 aircon .. good for cooling your nuts
11th May 2011 6:49pm |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
I had this. Dealer removed and checked and some of the foam had fallen down and partially obstructed the airflow. If its under any form of warranty then try that, if not, just disconnect the bottom section (the boll**k chillers!!) and have a poke around. Am sure you will find it. There is nothing in there to really break.
11th May 2011 7:24pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Cheers Landy nut. I'll take a look.
Would be wrong to have uneven chilling of the knackers for much longer.... Jon - 110 td5 [sold]. Currently Defenderless. |
11th May 2011 10:23pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i quite like the experience
18th May 2011 9:14am |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
make sure you dont get measured though before they have warmed up on a serious note the air flow seem to be stronger passenger side, i asume its due to it being closer to the condenser and fan 2004 TD5 Defender 90 xs station wagon |
18th May 2011 6:26pm |
