Home > Puma (Tdci) > Nakatanenga RAI, photo of your underhood hose..
Page 2 of 2 <12
agentmulder
Kuwait
Hi Keith,
I'm traveling at the moment so don't get access to email so much.
Looks like you've nutted it out though Thumbs Up
I shortened the flex house, just long enough by my estimation plus 50mm just in case.
I didn't use the supplied mastic, it was too thick and hard for what I assumed it was for. Used my own, quite a lot of it too.
Did you have fun getting out the old internal pipe ? Rolling Eyes Solved the bowel problem, working on the consonants...
Post #695816 24th Mar 2018 6:30am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I used the full length but spaced it evenly, particular around the brake servo. The old internal pipe? 2 cuts whilst in situ with a hack saw blade...run out of patience! m
Post #695837 24th Mar 2018 8:43am
agentmulder
Kuwait
Laughing yip, cut it myself!
It just want happening huh. Solved the bowel problem, working on the consonants...
Post #695838 24th Mar 2018 8:52am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
That's it finished. Glad it wasn't just me that got frustrated to the point of hacksaw.
Also having fitted it and put the rest back together I can see why there's limited photos available, it's hard to get a view of it.
Now just debating what to do about painting or not the outside of the cyclone unit.
 Keith
Post #695840 24th Mar 2018 8:56am
100inch
Forgot to mention. There is definitely an improvement doing the whole conversion including the RAI. I run a BAS tune and the engine is picking up a lot quicker. m
Post #696630 28th Mar 2018 3:44am
Keith5
Thumbs Up Inter cooler, hoses and remap are on the wishlist for this year Keith
Post #696645 28th Mar 2018 6:46am
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
i have the LHD version very easy to fit! just the airbox modification is improvising too screw it together
if i hold my hand on the top the engine stalls Cool Cool
grtz,
Tarcis
you need too knock the metal pipe in the airfilter housing dont use silicone or something! just tape it of when it's fitted in to place
Post #699409 8th Apr 2018 2:55pm
100inch
Didn't realise the old type of Mushroom fits the RAI. I may consider trying both types and see if there is any difference. m
Post #699510 8th Apr 2018 11:37pm
toetankh
Netherlands 2007 Defender 110 Puma 2.4 SW Stornoway Grey
Just wondering...
Would it be helpful to have the wing skin off (LHD Defender) during installation of this RAI? I'm in the process of installing a SD rollcage first, but don't see how it would be helpful with fitting the RAI.
However, if I have the wingskin on again, I don't want to remove it anymore (what a pain that is......)
Thanks for the advice!
Sven
Post #705540 5th May 2018 8:08pm
No, it wouldn't help at all since the inner wing would still be in the way. It's easy enough to fit with the wing in situ.
Post #705553 5th May 2018 8:45pm
toetankh
Thanks, RAI install postponed for a bit then.
Back tot fitting the wing skin Wink
Post #705572 5th May 2018 10:00pm
Chimbwe
Has anyone fitted one of these to the passenger side cabin air intake? Just wondering if it would help reduce the amount of dust sucked in when over landing. Not sure if there would be enough air flow to get the cyclone working properly?
Post #705583 6th May 2018 6:24am
100inch
Hmmm, having one on the passenger side would reduce visibility quiet a bit in my opinion. Particular when mounted to a cage. m
Post #705934 8th May 2018 5:33am
Page 2 of 2 <12
