Home > Maintenance & Modifications > Door locks... aaaaaaahhhhhhh!!!! |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
I haven't had to do it myself but I believe the end of the old barrel comes off by pressing a pin in the hole you can see. You then swap it to the new barrel.
See here - about 2 minutes in. https://www.youtube.com/watch?v=PQBM2qjjqCs Dave Green Goddess - 1998 Defender 110 300tdi |
5th May 2018 6:35pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
As a 'bush fix' I have swapped the tumblers over from the new barrel into the old one as I wanted to get the lock back in the door this afternoon. I did wonder whether there was a pin to push in but a) everything is crudded up with dry white grease so what looks like a pin wasn't moving & b) everything was crudded up with white grease so it wasn't evident that the barrel could be removed from the end piece. Will have a look again in the morning as it is very easy to remove the barrel from the door handle. If it comes apart then the tumblers will be going back in the new barrel & get used on the passenger door
Will update once I have done some more investigation! |
5th May 2018 8:13pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Yes you depress the brass looking pin and pull the end off and fit it to your new barrels, you’ve not been duped it’s the right part.
Click image to enlarge |
5th May 2018 8:19pm |
Thanks - will see what I can do in the morning. Cheers.
5th May 2018 8:51pm |
You can’t leave us hanging on like this! Did you get it sorted? |
10th May 2018 2:45pm |
NickMc, sorry for not posting an update, my D4 has died so I have had other things to focus on and not yet got around to trying to remove the bit from the end of the lock barrel. If time permits, this will be on my list of things to try and sort out today...
11th May 2018 8:51am |
Yay!!
After a few squirts of IPA, use of two pin punches & a small hammer I managed to get enough of a gap between the lock barrel & the end piece to get a small screwdriver in & lever the two bits apart. Result I now have a new lock barrel fitted to the drivers door. Passenger door will get the rebuilt new barrel once I've done that & third barrel will be kept ready for fitting to the rear door later in the summer once the canopy has been fabricated (note I didn't say this summer... ). Thanks to all for their input. Click image to enlarge Click image to enlarge Click image to enlarge |
11th May 2018 2:34pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5109 |
Result , plus you learn something new every day I like you had no idea about that little trick and I also would have thought it was the wrong part. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
11th May 2018 2:40pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
easy mistake and not many people have noticed
12th May 2018 10:04am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
thought I'd give this a bump as it proved very useful today.
11th May 2021 3:55pm |
Kev the Rev Member Since: 04 Jun 2023 Location: Ripon Posts: 32 |
Is it still possible to buy a lock barrel to match your key number?
I don't like carrying loads of keys It's for a 2007 TDCI if anyone knows the part number |
5th Nov 2023 8:03am |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 110 |
Morning all
I did the same job on mine, just a little late to the party to add help! You can order one barrel from LR… but.. for literally £15 more, you can get a genuine full lock set. (Note to self it does not include the shear bolts) As I have read up, the ignition barrel appears to have a shelf life.. I went all out and replaced all. Plus you never know who still holds a key for your car.. (Ok) not that they really need a key.. but you know what I’m saying Great job done btw! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
5th Nov 2023 9:27am |
